Anonymous
- Jan 1, 1970
- 0
It's really not that difficult. All you need is the Arrowhead PGM670 programmer, or any programmer that will change the values on the chip. The BHS2000D uses a 94C46, which is standard in the alarm industry.
Angry Man In Gauteng
Do It Yourself Home Security Alarm Forum. Ademco, GE Security, DSC, Visonic, DIY Forum
Technical Support => General Technical Questions => Topic started by: john rivers on November 24, 2004, 07:23:56 AM
Title: Brinks BHS-2000d hack
Post by: john rivers on November 24, 2004, 07:23:56 AM
I have a Brinks BHS-2000d that came with the house I just bought. I want to change the alarm code from what the previous owners had. Can someone tell me the pin out for the terminal connection on this model (I could just trace the runs on the circuit board back to the processor but I was hoping someone could just tell me).
Is it a standard serial connection? If so what is the baud rate setting? How many characters does the password have, or if all the boards use the same password, what is it? Thanks in advance for your help.
Title: Re:Brinks BHS-2000d hack
Post by: Security Monitor on November 24, 2004, 08:15:25 PM
John, The Brink’s 1000 and 2000 series panels are not designed for programming except with a special programmer. Even if you manage to connect to the system (through the panel programming connection) you will need the panel code to access the information. Should you manage to enter the correct information and read the information in the fields, unless you know the corresponding numerical field and data sequence, it will just read a numeric value in each field. The Brink’s system also uses a layer programming, so each field will control many functions of the panel’s programming.
Example, you enter field 100 (for discussion sake). You may know that a 3 in that field means it will send a message to a pager. So you enter a 3. What you don't know is that field also controls the sirens shut off that requires a 2. So to send a message to your pager and also keep the siren shut off timer in place you need to enter a 5 (3+2), but it also controls the panel's motion delay with a 4. So to have it call your pager, shut off the siren after 20 minutes and still permit you to have an entry delay on the motions, you need to enter a 9 (3+2+4). As you can tell, it requires knowing the numerical value for each function controlled by that field. Should you get hold of a technician programming guide, you will also notice some default values, like a 1 for that field. That means that 1 controls something they don't even want a tech to mess with so they don't say what it's for except that the value for what's programmed is increased by 1.
Should you attempt to connect via the phone line, you will also need the downloaders code AND you will need to know the remote programming access field and numeric values to enable the panel to accept the changes. This isn't something they show on any sheets and isn't even known by their non tech center staff.
The short of it is, it's not something you want to go playing around with. You could end up having the siren blaring for 1 hour every time you open a door, and sending a fire trouble each time you walk in front of the motion.
Post by: dave on November 25, 2004, 06:26:09 AM
for the amount of aggrivation you are intending to go through, why don't you just replace the panel before all of that....Brink's stuff is propriatary and made by Scantronic, and IMHO junk.
Post by: john rivers on December 02, 2004, 02:49:25 PM
Thanks for your advice guys, you talked me out of trying. The alarm works. It turns on the siren when the door is opened and the siren goes off when the alarm code is entered. I just was not comfortable using the previous owner's code so I wanted to change it. I guess I'll just live with their code.
Post by: Apex on December 04, 2004, 04:18:09 PM
If it's just the user code you wish to change, check your PM mailbox.
Post by: dingussquatbird on June 07, 2005, 09:51:27 AM
I recently bought a house that has a BHS-1000C already installed. The previous owner did not give me the code to unlock the panel... what are my options? How long is the numeric code that enables/disables the alarm, 3 digits, 4 digits... ? I talked to Brinks and the salesman that came out to the house said that the system would run unmonitored (which is my preference), but it had to be unlocked first. They are going to charge me to unlock the system plus make me sign up for 1 year of monitoring, at a cost of about $350. If anyone has any ideas on what I can do, please let me know.
Thanks!
Post by: brade8 on June 07, 2005, 06:21:18 PM
They gave you a bunch of bull crap. The panel will work just fine non monitored. Brinks is the only company or person that can unlock that panel cause they use there propriatary equipment. The salesmen didn't use the right lingo. All that would need to be done is to disable the phone option and change the code to whatever you wanted. If you know the code already then u shouldn't need them at all. I don't know there equipment since they are the only company that use it because they like to stick there customers with the idea they can never switch alarm companies without changing out there panel. Very bad way to do business. Theres no way you need to sign a contract for them to unlock it for you. Unlocking wouldn't help you anyways. This salesmen had one thing in mind. MONEY!!! He doesn't make any money unless you sign a contract so thats what he did. Made sure you signed some kinda contract so he would make money. You can buy a new panel for cheaper then that. It would be way better then there junk and you can do whatever you want with it. You can even get it monitored with any company you want. Just make sure you don't have wireless cause it probable won't work with any other system. If there is wireless on it then you would have to replace the wireless also which would easily cost more then 350. If I were you I would get rid of that brinks system. PS the user code is usually 4 digits or somtimes 6 on rare occations.
Brad
Thanks!
Brad
