BT9151 and 1200p60
HA1
Dec 24, 2003
53
:)Hey
Please need data sheet for:
-BT9151
-1200P60 (it is 8 pin ic)
THANKS . ;)
HA1
Dec 24, 2003
53
???Frind mixos where are u please help me.
mixos1
Administrator
Jul 13, 2003
581
I attach you a datasheet for 1200P60, I am not completely sure if this is the right one.. check it..
About BT9151 I can't find anything.. can u give more info? what is it?
NCP1200-D.PDF
  • NCP1200-D.PDF
HA1
Dec 24, 2003
53
???Hey,frind mixos
I find BT9151 ic in the wire intercom and that i read from
the chip,and there is no more inf. writen on the chip .
About 1200P60 i check it is right that i need . :-*
Thank u.
mixos1
Administrator
Jul 13, 2003
581
You are pretty lucky HA :D . Here is what i found:
BT9151 is equivelant to UM9151 and it is a Pulse Dialer with direct Phone line operation. 4 * 3 matrix keyboard interface. Supply voltage range of 2 to 5.5 V. 22 digit redial memory. Selectable make/break ratio. High speed test capacity.
and this is a usage schematic:
I attach you also the UM9151 Datasheet
UM9151-3.pdf
  • UM9151-3.pdf
HA1
Dec 24, 2003
53
;) :-*Thanks
Thank u frind mixos u are very good helping frind ,i hope to u the
happenese and good live . :-* :-*
Liza
May 31, 2004
http://www.onsemi.com/pub/Collateral/NCP1200-D.PDF
hi, here is a link to the datasheet on a 1200P60
