Building a simple radio scanner
Electro132
Feb 12, 2013
261
I would like to build a simple scanner which has a wide range of 10 000 hz to 30 000 khz or 10 000 khz to 30 000 mhz. Is there a simple circuit? I had a look and it seems like i could go with building a receiver based on these values but not sure how.
Any help is appreciated.
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
RF scanners aren't simple! Saying that you want to build a simple scanner doesn't mean that a simple design for a scanner exists.
Also your frequency ranges are confusing. 10,000 Hz to 30,000 kHz is actually 10 kHz to 30 MHz; a ratio of three and a half decades! And 10,000 kHz to 30,000 MHz is actually 10 MHz to 30 GHz, which is well into the microwave band!
No, there isn't a simple scanner circuit. You can build a simple AM receiver operating around 1 MHz with a tuning range of about 3:1 - it's called a crystal set. Beyond that, things rapidly become more complicated.
Not to mention that even if you were able to build one, it could never match the performance of a commercially built one nor the price.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Software defined radios (SDR) are becoming more practical to build, and that would be my starting point for a scanner. Since the radio is defined by its software, adding a scanner function is almost trivial. However, you must define a reasonable portion of the spectrum to examine. Ten kilohertz to thirty gigahertz is a bit much, even for a commercial spectrum analyzer such as the Tektronix - RSA3408A Real-Time Spectrum Analyzer which "only" covers DC to 8 GHz.
IMHO, a 100 kilohertz to 10 megahertz SDR with a scanner function could be designed and built by a skilled amateur.
14,485
Yup, an SDR radio covering that range would be a good start. Still requiring good electronics skills
