Jim Yanik
- Jan 1, 1970
- 0
Nah, you just grab the nearest passing squirrel. ;-)
Cheers!
Rich
the squirrel may get your nuts. B-)
Cheers!
Rich
-----Spare set of gloves or socks; good close fitting hat; map (compass
isn't much use without it); food for 3 days (nuts,raisins,chocolate);
billy; windbreaker or parka; leggings;
Yep, I do carry most of that, depending where I'm going, and the season,
etc, etc. And these days I don't go too far without the ultra-lite gas
stove. The list I provided was just the little survival pack, that goes
in regardless of place or season.
You wouldn't ge 100 million EPIRB buyers. We probably don't have 100
million GPS owners.
I appreciate the post about Australia. I wondered why so many google
searches for EPIRB end up there.
save someone's ass one day)
Matches, waterproof, in a 35mm film cannister
candle stub
Butane lighter, disposable
Zippo lighter
several Band-Aids and a crepe bandage
2-3 safety pins
a dozen or so Disprin
"Airguide" whistle, also has thermometer, magnifying glass and compass
built-in
100 mL bottle of alcohol.
Water purifying tablets
fish hooks and line
nylon parachute cord
Space blanket
Swiss army knife.
2 x CDs (Signal mirrors)
2-3 single edged razor blades
pencil and paper
small roll of duct tape
LED flashlight and spare batteries
Plastic bags large and small
A 35 mm cannister holding cotton wool balls soaked in vaseline (a
great firestarter)
Waxed cardboard box to hold most of the above (secondary duty as
firestarter)
It seems like a lot, but it packs up small and light.
Probably most importantly, I have read several books over the years
on survival, and carry that knowledge between my ears. It weighs
nothing. (1s and 0s weigh the same!) And I practice some of the
skills every time I can.
Barry
Jan Panteltje said:I have heard that if you go desert, then bring a sheet of clear plastic.
Then if you need water, dig a hole, put the plastic over it, with a cup
below, and a stone to dent it where the cup is.
Some condensation on the bottom of the plastic sheet will form and that
water will slide down and drip into the cup.
We did that back in Boy Scouts. It does work, although what isn't mentioned
is that the water collected is usually rather dirty... bits of sand & dirt &
what-not inevitably make their way onto the plastic sheet and into the cut.
Granted, if you're otherwise dying of thrist, I doubt you'd care...
below, and a stone to dent it where the cup is. Some condensation on the
bottom of the plastic sheet will form and that water will slide down and
drip into the cup.
Was that supposed to look like this?
_____ platic sheet ______
--| \ / |--------------- desert
| \ stone / |
| \ O / |
| (__) cup |
|_____________| hole
On my server it wrapped kinda funny.
I've seen diagrams of a version of this, where they cut up a cactus, and
lined the hole with cactus slices. Pulp side up, of course. ;-)
the other source of moisture you can add is to 'relieve' yourself intoJan said:You need to use a fixed size font.
Yes that would work too, lost of moist in the plant, but then may as well
bring a cactus press![]()
On a sunny day (Fri, 22 Dec 2006 00:11:35 GMT) it happened Rich Grise
the other source of moisture you can add is to 'relieve' yourself into the
ground adjacent to your still...
I did. I've been using a fixed sized font since I figured it out about
a decade ago.
_YOU_ need to use a fixed-sized font. >:-[ [ ed. note: ;-) ]
Which weighs more: a cactus press or a 1m x 1m sheet of 3 mil (.1mm?) poly? ;-)
We're talking about being lost here, after all. ;-)
Richard said:I wonder who foots the bill for trying to protect those idiots from
their own negligence?
They should get this year's Darwin award, and the rescuers who put
themselves at risk at taxpayer expense should be a close runner-up.
Rich
