Building Your Own Flyback Transformer
A friend gave me a little yellow toroid (ferrite?) with a winding
around it, that he had butchered from some non-working computer part.
I unwound the (thick!) wire, re-wound it with 10 turns of primary, and
50 turns of secondary.
I then built an astable multivibrator switching at 70 kHz, running off
3VDC, switching a TIP31, hoping to get a x5 multiplication of the
voltage.
I got exactly 0 volts out of the secondary.
Why is this?
Is there a minimum voltage requirement for flyback transformers?
Similar effect with 6VDC on the primary side.
At first I thought the yellow ring may be made of plastic, but a
neodymium magnet happily picks up the toroid...
I'm using an NTE587 fast switching diode on the secondary side.
Michael
default
voltage.
Why is this?
Michael
Have you put a scope on the primary to see if it is indeed toggling?
I assume your output is from the rectifier diode and filter cap on the
secondary and that one side of the secondary is common to the meter?
Sounds like it ought to have some output if you connected it properly
and it is toggling. The toroid material may not be ideal for the
frequency you are using, but there still should be some output.
Duty cycle problem?
I have no scope; I thought of using a sound card mic input + resistor,
but the frequency's too high.
I'll cut the frequency down by a factor of 10 (to 7 kHz) and listen
for a hum
Yep
What's the ideal frequency for this toroid material? Is it really
made of ferrite? I'm guessing it was from a noise suppression choke
inductor...
Michael
Say... when I wound the secondary, I wound in exactly the same
direction, overlapping the primary.
Was I supposed to wind the secondary in the opposite direction?
Michael
Rich Grise
voltage.
Why is this?
Are you running this single-ended? What provision have you made for
the half-cycle when the transistor is off - where does the flux go?
IOW, how are you resetting the core to prevent it walking away into
saturation-land? ;-)
Good Luck!
Rich
Good Luck!
Rich
The flux hits the diode, can't *quite* break it, then thinks, "Hmm,
maybe I'd better wait here for a few microseconds until the next pulse
arrives."
I'm a newbie at flyback transformers. (That's why I'm testing mine at
low voltage, lest I unwittingly emit subatomic particles in my living
room.) Is there a better way to do this, than just have one ultrafast
diode + filter cap in the secondary?
Michael
Good Luck!
Rich
Would use of an ultrafast bridge rectifier avoid the free, all-
expenses paid admission to Saturation-Land?
Michael
Eeyore
Well for starters, for flyback you tend to need a core with an air gap !
Go to powerint.com and read all their app notes.
Graham
Eeyore
Read some app notes. Google will help.
Graham
Eeyore
Depends on the material. Anywhere from 20kHz - 1 GHz.
Is it really made of ferrite?
How would we know ? It might be metal powder. Post a pic of it.
inductor...
Making it completely useless as a power tranformer.
But - for flyback, the biggie is the air gap. That's where the energy is
stored.
Graham
Eeyore
Hardly critical if you swap the leads over.
Graham
Joerg
arrives."
Flyback xfmrs need an airgap, you toroid probably doesn't have one.
neon
Oct 21, 2006
1,325
HOW YOU GOT ZERO ? what do you use for measuring finger tips.
default
Michael
It matters not a whit. Only time you care is when the phasing is
critical to the operation - like the winding is a feedback to your
oscillator circuit to keep it running.
Then you just swap the "start" with the "finish" to change the phase -
no need to switch winding direction.
Without a scope you're handicapped. Oops, visually challenged. How
do you know you are driving the toroid with a signal? You can do
things like monitor current or use capacitive coupling and a diode to
rectify the AC so your meter can read it, but a scope is lots better.
You also mentioned you only have 3 volts on the oscillator - you have
to drive the switching transistor on the toroid with enough voltage
and current to get it to saturate - you only need .7 volts with a
bipolar transistor, but with enough current to switch. 70 KHZ might
be too high for the circuit. Tip31 only has a gain of 25 at one amp
collector current.
One easy circuit that almost always works is a blocking oscillator.
One transistor with a tapped primary winding. Phase matters - the
feedback winding has to be out of phase with the collector.
See http://www.cappels.org/dproj/ledpage/leddrv.htm
It isn't a high power circuit - but it can be - lower the bias
resistance and use a cap around the resistor (drives it into
conduction faster and harder). Start with the circuit shown until you
get it working then experiment. The frequency will be dependent on a
lot of factors. In the 50's we used them to drive loudspeakers and
varied the frequency by putting the electrolytic feedback caps in
series with the bias resistor and using variable resistors to change
the pitch - I made a bike horn out of it and used it to look at
resonance in mercury vials.
I wind the toroids with a doubled over piece of magnet wire (bifilar
winding) then connect the start to the finish on one coil - this way I
may still miscount the turns but the center tap will always be in the
center. With ~15 turns of wire and no load on the circuit - the
output can be as much as high as 90-100 - and it will fry a 2N4401
most of the time - so keep the led in the circuit; your TIP31 is only
good for 40 volts.
no need to remove the wire you already have on, just wind over it
Joerg
Not at all, they can work quite well _if_ you keep any DC components out
of the flux.
stored.
Yep. Best would be to drive this core push-pull and capacitively coupled.
Michael, for heavier loads that can be done using a motor driver chip as
they can be found in printers, disk drives and such. Make sure the
rectification doesn't introduce DC flux and that there is a wee choke
right between rectifier and first capacitor to even out the load on the
driver.
Paul E. Schoen
It does not seem worthwhile to spend time and energy to do experiments on
unknown circuit components, especially without the necessary equipment,
like a scope or an LCR meter. Either of these can be obtained very
inexpensively, especially if you are willing to get an older model and
perhaps do a little repair work (which can be educational as well).
You can purchase toroidal cores with full specifications from DigiKey for a
few dollars, and then you can wind transformers that will perform
predictably. You can also probably get samples on-line.
For the test equipment and the cores, eBay can be your friend, and also
check out any local Hamfests that have electronic flea markets.
I would also suggest drawing up your circuit in LTspice, although
transformer modeling can be tricky. You could start with a sample circuit
for a flyback converter (5v 12v 20mA 1316.asc). It has a transformer model
that will work for what you are trying to do. It has a 40 uH primary and a
640 uH secondary, which is a ratio of 4:1.
Paul
Joerg
John said:
There is no industry wide standard for color code of toroids.
Your core could be solid ferrite (high permeability, low saturation amp
turns) or any one of a number of powdered iron formulas. Based on the
heavy wire originally on the core, I suspect it is powdered iron with
lots of air gap distributed all around the core between the iron grains.
As I said, different manufacturers use different color codes for their
materials. For example:
http://www.elnamagnetics.com/library/catalogs/MHW/MH&W International Powder Cores.pdf
http://www.uoguelph.ca/~antoon/circ/toroids.htm
http://zeus.cedcc.psu.edu/ind/irontoroid.html
http://www.qsl.net/ok1dxd/amidon.htm
A powdered iron core could work for a flyback design if the permeability
were high enough. This doesn't explain your zero output, though, unless
you have a very low permeability core.
Measuring where core saturation occurs is actually possible without a
scope. Wind on three windings, 10 turns each or so. Run one to the
soundcard output, one to the input. Start some level meter SW, FFT, or
similar. Send an increasing amount of DC current through the third
winding and see when the audio signal begins to drop off.
Rich Grise
I'd have to look it up; I'd probably put "flyback tutorial" or something
in google search.
Good Luck!
Rich
On Aug 27, 6:15 pm, Joerg <[email protected]>
Thanks to all for the replies.
Turns out my astable multivibrator wasn't multivibrating at all -
using a 555, I got it to work, kinda. My DMM measured 5VAC across the
secondary. Strange, since this is about what I fed it with on the
input (6VDC, switched, minus the drop from the TIP31A) - but it could
be the high frequency confused my DMM. I was out of alligator clips,
else I would have added the ultrafast diode and cap on the output - I
measured it raw...
More study needed, when I have more spare time... it's the kids'
bedtime now...
Michael
Joerg
measured it raw...
bedtime now...
Just don't expect much out of a TIP31. The 555 doesn't have enough
muscle to drive it properly. So wear goggles, seriously, because with
stuff like this parts can go, in chemistry speak, "exotherm".
