Buzzer Help
Rajinder
Jan 30, 2016
568
I have attached a copy of the voltge seen on a piezo buzzer. I need to ckamp this to 3V3 and then detect the edges of the waverform at 1.17 secs, feed this into a microcontroller and measure the time between pulses.
I was thinking of clamping the wavefor which is 30V by using a suitable resistor and zener diode at 3V3 or around that figure. This will remove the negative going part of the waveform. Then feed this into a differentiator to detect the positive edges and feet into a microcontroller I/O pin.
If the piezo was say operating at 20mA (for example), to calculate the series resistor with the zener is it simply a case of 30-3v3/20mA. Then ensuring power requirements can be satisfied i.e. wattage of resistor.
would this be then suitable to connect to the differentiator circuit? or would i need some further signal cleaning after the differentiator stage?
any help would be appreciated.
Best regards,
raj
Arouse1973
Adam
Dec 18, 2013
5,178
It must be the water draining away some of the magnetic field :)
Alec_t
Jul 7, 2015
3,818
Not unless you want 20mA flowing through the zener. The buzzer current is irrelevant. Make R=(30-3.3)/Izener. A zener current of just a few mA should be enough.
Rajinder
Jan 30, 2016
568
Thanks. If I put 5mA through the sender, that should be ok? Would there be a problem with the differentiator part of the circuit, just to detect edges or is there a better way to achieve this?
Best regards,
Raj
Alec_t
Jul 7, 2015
3,818
Personally I'd use a CMOS Schmitt trigger, instead of a differentiator, to get sharp pulse edges.
