Buzzing Makita DC1414 F charger
Cirkit
Oct 28, 2015
156
I have the above Makita charger which is buzzing with a variable frequency when the green LED flashes.
I have tried prodding the transformer and various components but the buzzing doesn't stop.
I don't want to start replacing capacitors on the chance that may cure the buzzing.
Attached are photos and a video showing the buzzing can be downloaded from this link:
https://ufile.io/v78dr3o2
Any suggestions on where I should start looking?
Thanks.
Martaine2005
May 12, 2015
5,318
Hi CirKit,
The free (slow) D/L doesn’t work.
Can you describe the buzz?.
Is it only when the LED flashes?.
Is it definitely a buzz rather than a high pitch tone?
Martin
14,317
Download worked for me.
It is a medium to high pitched sound (similar to an electric razor, but not so loud). The frequency changes with the blinking of the LED: LED on -> frequency high, LED off, frequency low. Notable peaks are around 4 kHz and 6 kHz:
Martaine2005
May 12, 2015
5,318
It sounds like the caps aren’t doing their job. Given the stresses these caps go through in SMPS, they are also the first components to fail.
I would replace them as a matter of course.
Martin
Cirkit
Oct 28, 2015
156
Thanks for uploading the spectrum @Harald Kapp.
@Martaine2005 do you have any suggestions which capacitors I should replace? Is it likely to be the main filter capacitor?
bertus
3,877
The mains capacitor could cause hum.
The output capacitor could cause screeming (high frequency noise), when the ESR is going up.
Bertus
bertus
3,877
When you change the fourrier size and look at the spectrum, the 100 Hz is good visible:
You will also see signals at 4000, 8000 and 12000 Hz.
Bertus
