C programming, function returning a garbage value
Luke Vassallo
Dec 10, 2014
33
I am creating a program that will check for a number if a number is prime or not. However the function is returning a garbage number when I use local variables.(works fine with global though)
the code looks fine to me however I can't understand what's going wrong.
this is the function
Gryd3
Jun 25, 2014
4,098
Can you post the section of code that calls the function as well?
Luke Vassallo
Dec 10, 2014
33
I fixed the problem. It was expecting that after the function is executed it's value will be changed to either a 1 or a 0. But then I called the function to execute the code and use the returned value immediately.
I was thinking of it the wrong way, it actually returns a value and not change the function's value itself
