Caddx Ranger 8980 power light out
bowood
Jun 15, 2022
Caddx Ranger 8980 home security system installed 1994; no problems til now. Red power light is out on one of the three control panels. First thing this morning we noticed that the Alarm and Ready lights were out; only Power was on. (The other two control panels display as usual) Manual gives no instructions for this situation. I tried some RESET sequences, producing no results. After 20 minutes or so the red Power light went out, though the keypad remains lit. System still signals the opening of an exterior door. We had two sub-second power flickers in the last 4 days. Two questions: What does Power light out mean? How to restore all three lights to working order?
Martaine2005
May 12, 2015
5,318
@ChosunOne will be a long shortly to assist you.
Please make sure you utilise his services fully as we pay him handsomely
Martin
ChosunOne
Jun 20, 2010
491
In the alarm industry, when we refer to a "Control Panel", we're talking about the "brain" of the system, a PCB located in a steel cabinet somewhere, usually in some out-of-the-way place like an unfinished basement, closet, or utility area. What you're talking about is 3 Keypads, the interfaces between User and Control Panel (or just "Panel"). May seem nit-picky, but in troubleshooting, it's really helpful if we're using the same terminology.
If one of your Keypads has the power led off and the other two KPs show it on, it probably means you have one malfunctioning KP. The Power LED shows that your Panel (the 8980 PCB in the steel cabinet) is getting its nominal 16.5 VAC power from your power transformer plugged into an outlet somewhere. Which it probably is, if two of your KPs are showing it is. The malfunction could be as simple as a bad LED, or it could be something more complex. How handy are you at troubleshooting? It's possible that your errant KP can be repaired, but I wouldn't bet on it.
Keypads are not considered field-repairable by dealers and are usually just replaced, but a KP that old is going to be hard to find and I personally would be wary of any replacement you might be able to find on eBay or wherever: Whatever any replacement's source, those KPs went out of production ~25 years ago. Since KPs have moving parts (the keys & their contacts), their lifespan is finite, and your other two KPs are on borrowed time. You might be able to find a replacement on eBay or similar, good enough to keep your system going another years, but it's rolling dice, and new/old keypads are usually expensive enough to make me think of buying a new system.
Congrats on maintaining your system for 28 years, but it was never going to last forever. I'm personally a big fan of keeping old equipment working, but I'm afraid you may be looking at using your system with just two KPs, or replacing it with something newer. I'm happy to offer advice if you go that way.
Oneofthesedays
Jul 31, 2025
If both key pads went dark at the same time. It would not seem likely to be a problem with the KP at the exact same time, even though they are 30 yes old.
What would be your next guess? FYI,Backup battery stills hoping good after charge, even temporarily changed out with new battery, but still no power to KP.
Thank you for your time and input.
