If you would like to use standard methods, then first choose the most reasonable ground point, i.e. node 'C'. There is no need to complicate the problem by converting circuit components (R) into equivalent conductance (G). Every complication is a new opportunity to make a conceptual or substitution mistake. Write the node equations with the nodes and branches clearly identified and segregated. My method is to begin every term in the node equation with that node voltage, subtract from it the adjacent node voltage and divide by the branch resistance to the adjacent node, repeat for all adjacent nodes and set the sum of terms equal to zero. Do this and you will get the equations I solved in #34. This is a mainstream approach, not the phantom reference explanation which I pursued as just an interesting aside.
