Calibrating Volt Meters
Glenn jacobs
Anyone have any good ideas for acurate volatage sources, with out the need
for standards. My hope is to get accuracies to plus or minus 0.1 Volts.
JakeInHartsel
martin griffith
JakeInHartsel
Do you mean
1V +- 0.1V thats 10%
or
100 +- 0.1V thats 0.1%
martin
Glenn jacobs
[4 quoted lines suppressed]
Do you mean
or
martin
Sorry should have been more clear. Plus or minus 30 Volts DC is the range
that I am interested in.
JakeInHartsel
AZ Nomad
Or just use a random voltage source and an accurate meter to calibrate.
Paul E. Schoen
[snip]
range
JakeInHartsel
You will definitely need something that qualifies as a standard, although
you may not need laboratory grade instruments. For 0.3% accuracy you need a
standard about two or three times more accurate, or about 0.1%. Most DMMs
are at least that good, but you need to have it certified traceable to NIST
to be sure. You can buy 0.1% resistors, and build a divider from 30 VDC to
a commonly available standard voltage, such as 1.2 V or 2.5 V, but you will
need to make sure it is within the 0.1% accuracy. Then you would need a
sensitive galvanometer to determine that the voltage difference between
your standard voltage and the divider is zero. In this case you would need
about 2 mV resolution on the galvo. This is the old way to do it. A
certified DMM is the easiest, but certification costs about $40 or more.
Paul
Robert Baer
JakeInHartsel
I like the following voltage references, as i can use a box with 9V
batery compartment to run the part which sources or sinks current.
No need for a power switch due to the *very* low supply current, and
the 9V battery can run down to where it would be useless for anything else.
http://www.intersil.com/products/deviceresults.asp?i=14927
If you need 30V, then connect 6 of them in series using them as a
2-terminal shunt regulator (Vout and ground).
Or if you can stand the burning of more power and a higher supply
voltage, use one as the reference to an opamp that has a gain of six,
and use common 0.1% resistors (make sure that the supply voltage to the
reference is limited to spec).
I
Ignoramus10768
I believe that a well charged car battery is a quite accurate voltage
source, at about 12.68 volts or so. Am I mistaken?
i
AZ Nomad
Yes.
It's barely accurate to a half volt.
N
Nico Coesel
I recently build a cheap +/- 10V reference using a 0.1% reference from
National, some 0.1% resistors and AD688 instrumentation amplifiers as
a buffer.
Jamie
JakeInHartsel
a fresh carbon cell was used in the old days.
i don't remember the the exact voltage but
something like 1.567 etc.
they do make reference diodes.
Richard Henry
Yes
T. Atkin
martin griffith said:
Do you mean
or
martin
A mercury battery like PX675 (though may be kind of hard to find) loaded
with 1.5K resistor(1mA load) will give, if memory serves me, 1.348V. Very
precise. Four significative digits.
Tom
AZ Nomad
It isn't temperature dependent?
T. Atkin
Good point!
Here I'm not quite sure but the temperature only affects the battery
capacity, not its voltage.
I'm gonna investigate further.
On the other hand, my suggestion is not really a good one because production
of mercury cells has almost stopped.
AZ Nomad
Good point!
Take that mercury battery, put a 5 1/2 digit meter on it and now you have
an accurate voltage source.
Jim Yanik
Most zeners are not stable and one would have to calibrate it and
put
it in a constant temperature oven and...
A number of *good* references have been mentioned that do not need
that kind of babysitting.
TEK video generators had a nice simple 2 transistor circuit for a temp oven
for their reference crystals,used a thermistor and a Darlington for the
heater.The whole thing fit in a little metal box about 2" square.
The oven will require some substantial amount of power,though,not really a
battery type of project.
