Cambridge SoundWorks Radio CD740
zipstah
Aug 12, 2016
3
Having a problem with CD ejection. There are two cd's inserted into player. Player will not eject cd's. Looking for direction on how to remove the cd's. Unit has not been opened since I bought it new. Cd player has always worked (and still does) with an occasional cd ejection problem. Thanks in advance for any help with this problem.
73's de Edd
Aug 21, 2015
3,730
Sir zipstah. . . . . . .
Pull the dust cover(s) and the discs are . . . . . EVENTUALLY . . . . . viewable and accessible .
If not readily accessible , ( scared to do a full teardown ) try a tongue depressor linearly overwound with SCOTCH clear packing tape . . .sticky side out . . . and taped TAUT at the end where you will be handling the stick.
THEN light up inside of slot . . . .view disc position . . . . insert depressor . . . . .press . . .stick . . . . .and s...l...o....w...l...y work disk out.
Clean "stickum" from recovered disc . . . .using radial cleaning strokes.
73's de Edd
zipstah
Aug 12, 2016
3
Thank you for your response 73's de Edd. I will attempt this. Once the dust covers are pulled I am assuming that they will need to be replaced? I am capable of pulling the unit apart with direction(s) . Just don't want to try with out a service manual or clear instructions on the procedure.
73's de Edd
Aug 21, 2015
3,730
Try procedure 1wo then . . . .but it is dependent upon a vewy-vewy bwite light! . . . . for inspection illumination..
I used a mini flexible gooseneck that used a 222 prefocused penlight lamp . . . .but now -a - days a WHITE LED version should be available.
73's de Edd
Lesli
Dec 29, 2016
73's de Edd
73's de Edd
hi
What is dust cover?
I have front partially removed but cannot totally remove
Need to take out disc
Tried the tape without luck
H
Can I take the front off?
