Camcoder and S video question
Gingre
I have a fairly mature Panasonic NV-DS5EN camcoder. It plugs into an
interface unit with Audio L/R video RCA sockets, and also has a pot named
S-Video out, and a cable for this. No mention of S-Video IN. So is the IN
function incorporated in the one S-Vide mini DIN(?) plug? There are 4 pins
and a shell. Otherwise, how do I put a signal INTO the recording (or is that
not possible?)
Alan Rutlidge
that not possible?)
Gingre
Alan
Did you mean to give me a reply? (BTW I meant port and not pot!)
Mr.T
Have no experience with this particular model, but many don't.
So is the IN
Possibly switchable input or output via a menu function.
If the socket is really labelled "S-video OUT", then it's doubtful.
There are 4 pins and a shell.
Normal for S-video.
not possible?)
It should be covered in the user manual.
Possibly only composite input, maybe via a 4 way 1/8" plug-cable combined
with the audio. That's what some camcorders use anyway.
MrT.
rverdon
Normal for S-video.
MrT.
I have a panasonic, different model NV77 but sounds like the same setup. The
only way I can record on the tape , other than by using the camera is via
the firewire port. If you have a firewire socket on that model then it
will be possible via a PC..
Note someone has asked the question here with a similar answer.
http://www.camcorderinfo.com/bbs/t4691.html
I also found other links indicating it is possible.
Russell
Mr.T
"rverdon" <verdonsATtpgi.com.au> wrote in message
the firewire port.
Yes, that's simply because your camera has no analog video input circuitry I
assume.
Assuming you can get the video into the computer. May need to buy an anaolg
video input card for the computer.
MrT.
e-micro
Gingre a scris:
not possible?)
It's S-VIDEO OUT only.
Search manual , maybe there is another port for input to record
video....
