Can anyone help identify this diode housing?!
Anon_AM
Hi everyone. I'm struggling to find out the correct name of this black component housing on the left of the photo below (to mount old diodes to a pcb).
Can anyone help with what they're called, and where I can get them from?!
Thanks so much!
Martaine2005
May 12, 2015
5,318
Hi Andy,
I am replying to 'bump' this post. You have me intrigued. Maybe the more (senior) members may know.:D
Can you supply us with any other info?
When you say 'diode', a discrete diode or lazer diode?
I typed every imaginable search term and found nothing!!
What makes you think it is a tool for mounting diodes to a pcb?
Martin
14,487
I have never seen anything like it either
Anon_AM
It is certainly an odd one! The only time I've seen it was on a PCB, being used to house an old germanium diode which (if you can imagine) was strapped in with one leg wrapped over the top. I actually found this picture during a google search for transistor sockets, and it reminded me to try and find out what it is!
Martaine2005
May 12, 2015
5,318
Well there's my problem......I didn't search for transistor socket:p
Martin
shrtrnd
Jan 15, 2010
3,902
Just an opinion here.
In the 'old days', it was common to mount large diodes vertically to save space on a PCB where space was at a premium.
It served a couple of functions. To save space on the board, to keep the diode up off the board for heat dissipation, and provide a rigid support for anti-vibration protection.
My guess is that's a 'special purpose' mount made for the instrument manufacturer specifically for a particular purpose in the instrument. A 'special order' item.
I've seen a lot of simpler mounts made for the same purpose in a lot of equipment. That one seems like a more elaborate configuration.
I don't think you're going to find another one like it made for mass-production and distribution by a manufacturer.
Minder
Apr 24, 2015
3,561
My guess also it is a OEM produced part, possibly to enhance the heat dissipation of a leaded diode, as the wire connected to a power rectifier diode is generally large guage to act as its heat sink.
M.
