Can anyone help me identify these components
jamine16
Jan 16, 2013
6
Hi, I need help identifying the 3 components I have highlighted.
Also it would be great if somebody could point me in the direction of where to buy some.
Many thanks in advance.
14,289
The two at the left are probably ceramic capacitor. The one to the right a resistor.
432 means 43*100 OHm = 4.3kOhm
The capacitors have no visible marking, it is probably on the underside. No chance of identification without de-soldering them.
jamine16
Jan 16, 2013
6
I have de - soldered many of these and there is no marking anywhere.
Andyjm
Feb 7, 2014
11
We use a lot of caps like this at my work, and generally the only way we can identify them is to desolder them and check them with a capacitance meter. If you measure them on the PCB you won't always get a proper reading depending on what else is on the circuit. Hope this helps
Yep, I'd agree with that.
jamine16
Jan 16, 2013
6
Thanks for the info.
So if I test them on a capacitance meter and came back with the results, do you think you would be able to identify them?
Andyjm
Feb 7, 2014
11
I think I could certainly try, and if I can't then I'm sure someone else on the forum could.
14,289
Once you've tested them, you've identified them. Capacitance and size are relvant parameters. From the picture I don't think these are special with regard to voltage. Typically this size is rated 50V, max. 100V.
jamine16
Jan 16, 2013
6
If it helps, these are on a key fob with a 3.6v battery.
Andyjm
Feb 7, 2014
11
My apologies, I thought you meant.identify them as in 'what are they doing in the circuit?' If not, then as above, once you have the values you're done.
