Can Anyone Identify This Component?
Status
Not open for further replies.
Tek1
Mar 12, 2016
3
Hi, can anyone please identify this component for me please? I believe it is a low power triac thyristor or something along those lines. It did have a 3rd lead but broke when I removed it to test. It came from a speakon output circuit on a Behringer PMP6000 mixing console. Unfortunately I cannot get any service manuals on these consoles, and the numbers I entered off of the component on Google has not returned any information. I would appreciate any information I receive.
The connections to the surviving device appear to be the same and consequently it is probably the same device.
Do you have a multimeter?
OK, if it has a diode check range, measure each pair of leads (both ways) and tell us what you read for each.
For each measurement you'll have to tell us which lead the red probe is on, and which the black probe is on.
Do the same for the busted device too, there will only be two measurements.
Tek1
Mar 12, 2016
3
Busted component as follows:
Blk - Centre Lead
= 848
Red - Right Lead
Good Component:
Blk - Centre Lead
= 850
Red - Right Lead
Measured the same on the left lead too
ok, its probably a transistor. What voltage is supplied to this circuit?
andomando
Jul 11, 2013
6
It is a A56 TRANSISTOR as per schematic.
14,487
I doubt that since none of the other components match. The T3 position on the board should be swarming with resistors for example.
agreed
@andomando you have given incorrect info ... you schematic doesn't match the circuit board shown by the OP
If you indeed have the service manual, then please show the correct part of the circuit
Sunnysky
Jul 15, 2016
577
If it has a Triac and a 2 legged active part, it must be a DIAC
Status
