Can electricity flow through air w/out sparking?
Don Klipstein
Yes. Tesla even had ideas about supplying power to machines that way.
In a more modern context, that's how RFID tags are powered: there's no
battery in the chip to drive the transmitter, the power for that is
extracted from the carrier of the probe signal.
Of course, all of this "electricity through the air" is AC, and is in
conjunction with associated magnetic fields.
Well, there is no movement of charged particles through the air then.
The form of energy flowing through the air is not electricity but
electromagnetic radiation. That can even flow through a vacuum where
there are no charged particles, molecules, atoms, or any of the usual
subatomic particles.
As for electricity to flow through air without sparking - that can be
done, although not often practically, and there is a name for that
phenomenon - "ionic current". In an ionic current, charge is carried by
movement of ions. Where there are ions, there may also be some free
electrons available to move charge.
Ionic currents are usually less than 1 microamp. They are hard to
target over major distances to anything other than a greatly isolated
conductor (such as a target in the middle of a room from closer to the
target than to the nearest wall, floor or ceiling).
Ionic currents mostly come from corona, although they could flow through
air ionized by ionizing radiation. If you experiment with sources of
ionizing radiation that are short of very significant health hazard, don't
expect 15 volts to push through more than a few nanoamps (and that may be
optimistic). And don't expect blacklights or UV LEDs to make air
conductive - doing that with UV requires wavelengths below 200 nm, maybe
well below (184.9 nm ozone-forming mercury wavelength may not work).
Don Klipstein
Not precisely. They were, however, able to create an electromagnetic
field, which varied at audio frequencies, which was able to pass through
the air without arcing, sparking or coronal discharge. Philo Farnsworth
built on their work.
You are talking about what I think of as capacitive coupling rather than
electromagnetic radiation? Yes, that does happen, and is the main
mechanism for fluorescent lamps and neon lamps to light up a few feet from
a Tesla coil.
Source and target are effectively plates of a capacitor, usually a
non-ideal capacitor. The air (vacuum also works) is the dielectric.
This is normally not an efficient way to move power, although a few
exceptions to this could be made as laboratory curiosities - and then
optimistically that can transmit power efficiently over a distance maybe
the length or the width of the lab, and then probably only to a constant
impedance load, and with eficiency still easily exceeded by that of using
wire.
But with even low efficiency of moving power this way, plenty of audio
circuits run into problems with AC line power getting into them that way,
and some amplifiers run into trouble with this coupling means transferring
a bit of the output to the input.
A lot of audio circuits would get easier and a lot of shielding would
not be needed if the dielectric constant of air was zero rather than close
to 1. However, speed of an electromagnetic wave through a material is C
divided by square root of product of permeability and dielectric constant
of that material, so it appears to me that air having dielectric constant
much below 1 is going to be hard to find!
Salmon Egg
Each time I see this thread title, I get more upset. Yes! Look up ionization
chamber/
Bill
Without a unique definition for the word "electrcity," this discussion
makes no sense.
In most books the word "electricity" means electrical energy. Or
in other words it's 60Hz EM radiation being guided along a 2-wire
transmission line.
Search google for keywords "KWh of electricity." Then search
on "coulombs of electricity." The more common use by far is
electricity=energy. Therefore a flow of electricity is *not* an
electric
current, and a flow of electricity is measured in watts, not amps.
When electrical energy flows across a circuit from a source to a
load, it always flows in the region surrounding the conductors
and not inside them. The flow is described by the cross product
of the e-field and the b-field outside the wires. Inside the wires
the e-field is insignificant, and since the small field is axial, it
gives an energy-flow vector which is *inwards.* This makes
perfect sense, because wires become warm only because electrical
energy is flowing from the surrounding space and into the metal.
That's a flow of charge, not a flow of energy or "electricity."
Note that scientists have for the most part abandoned use
of the word "electricity" to mean charge. Faraday and Maxwell
may have used it, but since the early 1900s the textbooks
have dropped it. They no longer mention "quantity of electricity"
but instead call it "quantity of charge."
Well, it's a current density. So a more appropriate measure
would be 1 microamp per square millimeter, or something. If the
ion drift is a meter per second, then this implies that a
microcoulomb worth of charged air can take the form of a
cylinder 1M long and ~1mm in diameter
If 1uA/mm^2 were a typical value for non-corona, then we could
silently transmit 100uA through a 1cm pipe, or 10mA through a
10cm pipe. Hmmm, sounds a bit large when compared to the
current on the belt of a classroom VandeGraaff machine.
They are hard to
Nikola Tesla was putting vacuum bulbs on the top of small Tesla Coils.
They produce a fan-shaped visible glowing beam several feet long.
Today we would describe this as a pre-ionized path created by x-rays
then lit up by a few milliamps of high-freq current. With x-rays
involved, we can convert the air into a fluorescent lamp. Use it to
light up your bedroom and also light up your internal organs at the
same time. What fun!
((((((((((((((((((((((( ( ( (o) ) ) )))))))))))))))))))))))
William J. Beaty Research Engineer
[email protected] UW Chem Dept, Bagley Hall RM74
[email protected] Box 351700, Seattle, WA 98195-1700
ph425-222-5066 http//staff.washington.edu/wbeaty/
I'm talking about AM radio - and maybe I'm using terms so loosely that I
am using them incorrectly..
Salmon Egg
I can believe that!
Bill
-- Ferme le Bush
