Can I remove DC motor driver's speed control potentiometer and drive it with microcontroller DAC output ?
R1S8k
Jul 28, 2018
24
I was searching for 1-ph DC motor driver board that I can change the speed with a microcontroller.
The drive signal should be with DAC signal, because I'm using a PLC with relays as main output switches, but there are couple DAC output 0-10V. Which are DA0-DA1 on this pin layout:
The motor driver board is this one:
I think this driver board uses only a MOSFET with gate driver voltage using the potentiometer.
So my idea is to remove this potentiometer and instead connect the DAC lines from the PLC. Would that works ? theoretically I think it should work.
danadak
Feb 19, 2021
1,104
That is a PWM controller, so question is does the pot a part of
timing control on duty cycle or is it a V input to a PWM generator.
Can you get a schematic of board and/or part numbers of ICs
on board ?
Regards, Dana.
danadak
Feb 19, 2021
1,104
Post a pic of topside of board where one can read the part numbers. Can you
find a schematic on web ?
You are looking for a "Voltage to PWM" if your posted board has no PWM on
it. And you have to match DAC range out to PWM range V input. Search
Aliexpress using that term, many hits.
This is how simple that problem can be with a trivial solution using Arduino :
Basically this generates Arduino code from blocks you setup (right hand window). Uses 8 pin
dip part. But we need to know more specs and config about your board.
Regards, Dana.
crutschow
May 7, 2021
991
You need a voltage to PWM board such as this, to drive a PWM to Motor driver, such as the D4184 posted by BJ.
