Can network, video and sound cables be combined to save space?
Gilden Man
I wondered if it is possible to somehow combine a twisted pair network
cable, s-video cable and stereo audio to enable them all to be run through
a narrow channel?
This is to get all these signals from a PC in a spare room to cable
modem, TV and stereo in another room. The total run will be of the order
of 10m.
The space available is rather small and three seperate cables are not
going to be possible to channel neatly.
I realise the network and s-video cables are rather high frequency. The
cable modem is 100Mbit, but I guess I could tweak something at the PC end
to get the link down to 10Mbit. Afterall the cable modem is nowhere near
even 10Mbit.
Standard line-out audio cables usually have a larger cross-section than
audio cables, but I guess these could really be very thin? This isn't
going to be an audiophile setup, but just something to get it to work.
I guess composite video would be going backwards as those co-axial
cables are always fatter and stiffer than S-video despite the awful
picture.
Any advice would be very welcome.
Cheers.
Mike T
Gilden Man said:
a narrow channel?
of 10m.
even 10Mbit.
picture.
Cheers.
If you want to send the signals over the same copper wire, then NO, there is
no way as they all share the same frequency range. If you want to bundle
the cables close together, then as long as the audio and video cables are
shielded, then you can place them close to each other.
Mike T
DaveW
Getting a sound card to drive a 10m length of audio cables is iffy at best.
You may overtax the soundcard's output circuitry with an impedence mismatch.
The s-video cable at 10m is also questionable at best.
Gilden Man
["Followup-To:" header set to comp.sys.ibm.pc.hardware.video.]
I've got 15m of audio from my PC to stereo. I do have a half decent
Audiophile 2496 sound card which has stereo phono connector pair line-out.
Although my previous SBLive value had no audible problems (apart from
those inherant) with the same cable, but with a 3.5mm jack to two phono
connectors adapter.
Strange I also have a 15m s-video lead from my PC with a great quality
picture.
Cheers.
Gilden Man
Of course I don't mean that.
I know that is possible. That's not what I asked, but thanks.
