ilianaboone
- Aug 11, 2023
- 38
- Joined
- Aug 11, 2023
- Messages
- 38
In environments such as large campuses, farms, or underground utility tunnels, traditional point-to-point LoRa communication often encounters "signal dead zones" due to physical obstructions.
The core advantage of a Mesh network lies in its "decentralization" and "self-routing" capabilities. Every node within the network is equipped with data forwarding functionality; when a specific node is unable to communicate directly with the gateway, it automatically identifies a neighboring node to serve as a "stepping stone," relaying data back through a multi-hop path. This mechanism not only vastly extends the communication range—theoretically allowing for infinite extension—but also enables network self-healing: even if a specific node fails, data will automatically reroute via alternative paths. For users requiring the deployment of sensor networks across vast and complex environments, LoRa Mesh technology offers a highly reliable, wire-free, and ideal solution—effectively consigning "signal dead zones" to history.
