Can somebody help how to get desired coil inductance
dorke
Jun 20, 2015
2,342
Welcome to EP.
Here you have a guide and calculator (there are many others on the web).
You can also buy ready made standard coils.
dorke
Jun 20, 2015
2,342
An example:
iron core, μ=100
diameter 1 cm
length 10 cm
No of trurns=100
You get 0.99mH (put the values in the calc. and check).
Note:
1. the wire is 10/100=1mm thick.
2. you can play with the diameter,length and turns to get the same results in other sizes.
michael1978
Mar 17, 2012
388
An example:
iron core, μ=100
diameter 1 cm
length 10 cm
No of trurns=100
Note:
thanks a lot...
