Hello, can somebody help wich transistor is like bfg520
michael1978
Mar 17, 2012
388
Halo,
i am working on oscillator in multisim, but in database in multisim they dont have this transistor
can somebody help to find equivalen transistor please.... for multisim thanks
Is this oscillator working up to the GHz range? The ft (Transition Frequency) of this transistor is 9GHz.
if an ft of 6GHz is OK, then you could try this. The package is different so you'll have to do a bit of redesign of the board. There are others at Digikey. Other suppliers may have different stocked parts.
michael1978
Mar 17, 2012
388
I dont find in multisim, and also is for 88MHZ-108MHZ, I found in internet local oscillator
michael1978
Mar 17, 2012
388
is for frequency 88MHZ -108MHZ
For 100MHz you could try a BF199, which is a common one.
kellys_eye
Jun 25, 2010
6,512
Isn't that one obsolete now?
Either way, if you use some supplier websites and their parametric search function, some sites even have multisim files for the devices (iirc).
michael1978
Mar 17, 2012
388
Sorry but i realy dont know, i am searching on internet to find equivalent transistor bfg220, but i dont find nothing because first i search on internet, after i come here to ask for help
Well, why don't you tell us what RF transistors are available in multisym, then?
Well, look at the specs of the BFG520 then at the BFG transistors you have access to. Pick one that is close.
michael1978
Mar 17, 2012
388
Is possible to put the schematic, because it was not so good picture in document maybe i make mistake….
WHONOES
May 20, 2017
1,242
If your Multisim uses the spice platform, Try the model below.
You should be able to copy and paste into you program!
From: C:\Program Files (x86)\SIMetrix-SIMPLIS Elements_810\support\Models\bipolar.lb, line 143
*From Philips SC04 "Small signal transistors 1991" and NS Discrete 1978
* Base resistance not modelled - no info. CBE estimated. Vce(sat) estimated.
.model BF199 npn ( IS=1.61E-15 VAF=35.8 BF=150 IKF=0.0467 NE=1.3552
+ ISE=1.494E-14 IKR=0.001 ISC=1.00E-14 NC=1.5 NR=1 BR=5 RC=10 CJC=5.00E-13
+ FC=0.5 MJC=0.2 VJC=0.8 CJE=5.00E-12 MJE=0.4 VJE=0.6 TF=1.86E-10
+ ITF=0.045 VTF=3 XTF=50 RE=1)
michael1978
Mar 17, 2012
388
Thnx for help but i use LTSPICE and multisim
WHONOES
May 20, 2017
1,242
LTSPICE uses a version of Spice so will probably work.
I use Simetrix Elements which is the best simulator I have ever come across. The BF199 is in my model data base. Simetrix Elements is free to down load but has a limitation on the number of nodes. That has only ever been a limiting factor on very large sim's that I have tried.
