Can someone tell me what this part is called..
edg
Aug 23, 2018
4
Hi
Can someone please tell me what this part is called and also a link to were i can find this part..
It the end plug for a charger..
thank you,,
edg
Aug 23, 2018
4
Thanks but its the other end of the USB..
KJ6EAD
Aug 13, 2011
1,114
If you need the connecting cable, it would likely be USB A to Mini-B like this:
https://www.walmart.com/ip/C2G-2M-U...75035&wl11=online&wl12=29899343&wl13=&veh=sem
73's de Edd
Aug 21, 2015
3,730
Sir edg . . . . . .
ABSOLUTELY BRILLIANT . . . . . job, of obscuring the board identifier . . . but all is not lost.
As you can see, it is a Micro USB connector (or even the option of a std USB if so needed.).
NOW . . . . .do you need any more info than this . . . ?
https://www.alibaba.com/showroom/tp4056-charger.html
With that board identifier derived from the IC chip that the board is based upon, it being the
TP4056 . . . . . .with all of its relevant treasure trove of info, being contained within this
data sheet.
https://dlnmh9ip6v2uc.cloudfront.net/datasheets/Prototyping/TP4056.pdf
73's de Edd
