Canon A420 camera
  • Thread starter Adrian Tuddenham
  • Start date
Phil Allison
"Adrian Tuddenham"
That seems to be the most likely cause. I have found a firm that will
repair it (with a guarantee) for £72, so that is my least-bad option.
** Seeing as cold temp caused the problem - try warming the camera ( to
say 40C with warm air ) and operating the shutter over and over and tapping
on the lens assembly.
Cost you nothing and you got nothing to lose.
...... Phil
Adrian Tuddenham
Geo said:
Have you looked at the price and spec of a Canon replacement? e.g:-
<http://www.canon.co.uk/For_Home/Product_Finder/Cameras/Digital_Camera/Pow
erShot/PowerShot_A495/>
That does look pretty good as long as I can get the pictures out of it.
It says it will take SD cards, so my external reader might work with it.
(I seem to remember some memory card size limitation on either the
reader or the camera, can't remember which.)
-- ~ Adrian Tuddenham ~ (Remove the ".invalid"s and add ".co.uk" to
reply) www.poppyrecords.co.uk
Phil Allison
"Geo"
** The A495 is no replacement for the A420 - since it completely lacks an
optical viewfinder.
The A420 has one with inbuilt zoom that actually tracks the main lens -
without an optical viewfinder, such cameras become near useless in daylight
because the LCD screen is washed out.
I have owned an A430 ( near identical to the A420 ) for the last 4 years.
.... Phil
Phil Allison
"Jeroni Paul is a TROLL"
Given all your described sympthoms I would say it is the CCD sensor
starting to fail.
** Shame how it works fine when viewing on the LCD display.
..... Phil
Adrian Tuddenham
starting to fail. It is showing some dark rows across the pictures,
typical of problems with these sensors. These dark rows make the
camera think the picture is darker than it is and increases exposure
to compensate. When you see the picture on its LCD live it is not
analyzing all the rows but a small fraction and these failing rows
have no impact at all, so it appears to work properly. But when you
take the photo it processes all the information.
That sounds quite possible - especially as the sensor had been exposed
to very cold conditions for the first time and I now discover that
sensor faults were not unknown in early versions of this model.
I think the sensor will have to be replaced (if worth) but meanwhile
you can lower the exposure manually as you did as a workaround.
I've sent it away for repair and the quote was for a 'replacement lens
unit' (which presumably includes the sensor).
Consider also that overexposed photos may be corrected to some degree
with an editing program that can correct brightness/contrast. I get
quite good results with MS Office photo editor, my camera has a
tendency to take pictures too dark mainly under artificial light and I
fix some of them before printing.
Most pictures were so severely 'crushed' that no recovery was possible -
I did manage to use one but it was a struggle.
