Capacitance multiplier Power Supply
kbyrne
Jan 23, 2011
69
What I have is a idea I need technical advise about. Needs 36vdc @ 4A. Transformer in front of this board
24vac @ 5A. A normal power supply of same transformer Bridge rectifier and 4700uf @ 50wvdc comes out the end at 36vdc. How will these parts work out as I need help figureing out which formula's to use. I need to be near as possible to 36vdc out the end for two 12-Watt amplifier boards. Are my calculations correct? Thankyou.
12watt.brd.pdf
12watt..pdf
  • 12watt.brd.pdf
  • 12watt..pdf
