capacitance value to add delay in circuit
bobdxcool
Mar 9, 2012
98
I am using a relay to turn on/off a 12V motor. I wanted to add a delay in the circuit by adding a capacitor across the relay. I wanted to know what value of capacitor should I use to introduce a delay of 1second in the circuit. What is the relationship between the capacitor value and delay value ?
This is the relay I am using, amazon.com/SainSmart-4-CH-4-Channel-Relay-Module/dp/B0057OC5O8 I am activating the relay using a raspberry pi. The raspberry pi is in turn connected to a ULN2803 Darlington array. This is the schematic, i40.tinypic.com/xknc53.png
Gryd3
Jun 25, 2014
4,098
The capacitor is only one part of the circuit required to make a delay.
Do a quick google search on RC Time Constants and you'll get a better idea... there is one problem though...
They gradually gain/loose charge... so the current required to turn on the relay will gradually build-up, it won't simply be a 1 second pause and a 'click' of the relay.
This would cause some variance, and the delay may not be stable.
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Do you want to delay the turn-ON of the relay or the turn-OFF?
You might be able to delay the turn-OFF by adding a diode and a big capacitor, especially if the relay coil doesn't draw much current.
For delaying the turn-ON, adding a capacitor isn't practical. You would need something like an SCR with an R-C delay on its gate.
Tell us the rated voltage and power consumption of the relay coil and we can suggest something.
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Gee, you are using a raspberry pi to activate a relay? Surely you can program the delay you need instead of using old school analog technology?
