Capacitive reactance affecting voltage divider output
Rajinder
Jan 30, 2016
568
Depending on your goal, and why you placed the capacitor in series with the voltage divider, if your desire is to minimize the capacitive reactance effect of the capacitor on the resistive voltage divider, then you will require as large a capacitance as possible. Allowing |Xc| = 1 / (2 π f C) to approach zero by arbitrarily increasing C without bound would accomplish that goal, but you must also consider the effect of whatever source impedance is driving the series combination of the capacitor and the two resistors, as well as whatever load impedance is in parallel with the lower divider resistor. All this will involve the arithmetic of complex numbers, which clearly you do not seem to understand yet because of your incorrect statement:
Reactance is not the same as resistance, and you cannot simply add 20 kΩ capacitive reactance to 10 kΩ ohmic resistance to obtain 30 kΩ to use in the DC voltage divider equation. The AC voltage divider equation is Vout = Vin [ Zlower / ( Zlower + Zupper ) ]. Impedances are complex numbers and their arithmetic is different than the arithmetic used with real numbers.
A capacitor in series with a resistor has an impedance, |Zeffective| = [Xc2 + R2]1/2. The voltage divider output is NOT Vout = Vin [ Rlower / (Rlower + Rupper + Xc) ]. Instead Vout = Vin [ Rlower / ( Rlower + Zeffective ) ]. The addition of Rlower and Zeffective in the denominator is a complex number addition, and the fraction Rlower / (Rupper + Zeffective) is a complex number.
I will ask again one final time: WTF are you trying to DO?
Hi
Thanks for this.
Basically my friend has a piezo buzzer with three wires. When the piezo has been driven (he monitors the output) via the voltage divider into a PIC. Trying to differentiate if any wires may have broken off, or not connected.
He says that he gets a different waveform when the piezo is connected to when the wire (s) have been removed.
So he is trying to check if the piezo is connected or not or if any wire has broken offf.
Audioguru
Sep 24, 2016
3,656
A piezo transducer is a speaker or microphone. It is fed AC or produces AC. It has two wires.
A piezo beeper has a built-in transistor oscillator. It is fed DC. Its piezo crystal has three connections: output, ground and feedback.
We do not understand what you say your friend is doing. If he is simply checking if the piezo is connected or not or has a wire broken off then why doesn't he look at it to see.
Rajinder
Jan 30, 2016
568
Hi
Thanks for the message.
The unit is enclosed, so he cant look at it. He must periodically test it (once a week) to ensure it is connected.
Let me guess.
The device is a piezoelectric alarm module (like a sonalert).
It has three wires. Two are connected to power and the third is a logic input used to turn the alarm on and off.
I love these guessing games.
