Capacitor choice question
Hi there, I'm looking for a DC blocking capacitor with C ~ 0.1uF (for
impedance reasons) that will take fairly high AC power through it. At
the upper end, I'm going to be pushing about 5W (at 10 MHz AC) of power
through this cap, so I'd like it not to turn into a puff of smoke. Any
suggestion as to the type? I figure that electrolytic is out, and that
probably ceramic is fine, but I wanted to make sure. Oh, and I also
need the cap to be leaded, since it fits into a PCB.
Thanks for any help!
Jesse Wodin
John Woodgate
I read in sci.electronics.design that [email protected] wrote (in
What is the current? The power doesn't matter, the current does.
Any suggestion as to the type? I figure that electrolytic is out, and
that probably ceramic is fine, but I wanted to make sure. Oh, and I
also need the cap to be leaded, since it fits into a PCB.
Well, yes, ceramic, but 99.99% certain not a general-purpose 0.1 uF
multi-layer, even one with leads. You probably need the type of
component that's used in transmitters.
Wow, I guess I found what I needed. Cornell Dubilier makes "High
frequency" mica caps (type CDV16). Specifically
CDV16FF102J03 1nF 2.2A max continuous current at 1MHz ($3.110 at
NewarkInOne)
Pooh Bear
5W isn't much. I'm looking at an application that shoves ~ 3kW through
0.47uF for comparison ! Check the impedance curves at 10MHz though.
Graham
Phil Hobbs
NewarkInOne)
Wow, that's 350V RMS at 1 MHz dropped across that poor capacitor.
Cheers,
Phil Hobbs
John Woodgate
NewarkInOne)
Oh, well, if one 100 times smaller than you asked for is OK, enjoy!
John Woodgate
I read in sci.electronics.design that Pooh Bear
5W isn't much.
100 A at 50 mV? (;-) What current is associated with your 3 kW?
W
Winfield Hill
Phil Hobbs wrote...
I drop 7000V RMS at 1MHz across some of my capacitors. :>)
John Woodgate
I read in sci.electronics.design that Winfield Hill
You must have friends in the FCC! (;-)
Phil Hobbs
Winfield said:
Phil Hobbs wrote...
Admitting that on Usenet was a serious mistake...
Expect a call from People for the Ethical Treatment of Capacitors.
(And I bet even *you* aren't twisted enough to do it at 2.2 A.)
Cheers,
Phil Hobbs
W
Winfield Hill
Phil Hobbs wrote...
It's somewhere between 5 and 8 amps, I don't remember right now.
OK, I'll admit it, the cap was a glass vacuum tuning capacitor.
Pooh Bear
I anticipated that requirement was unlikely !
About 20A ( @ 100kHz ) . It's a job for a polypropylene type. It gets warm.
Graham
Phil Hobbs
Winfield said:
Phil Hobbs wrote...
Ah, gotcha. Air America on AM.
Cheers,
Phil Hobbs
Ross Herbert
NewarkInOne)
1nF is a lot less than the ~100nF you specified so you'll need 100 of
'em to get this value. At least they will handle the current better
with so many in par'l.
Jon
Jesse,
I'm a little confused by your requirement. An ideal capacitor will
dissipate zero power, regardless of the current. Do you mean that you
are delivering 5W of power to a load through the capacitor? In this
case, you need to calculate the load current (Iload) that will flow.
From this, you can calculate the resultant voltage that will appear
across the capacitor. V = (Iload)/(2Pi*f*C). The power that will be
dissipated by the capacitor depends in the equivalent series resistance
(ESR) of the capacitor. P = (Iload)^2*ESR. You can get the ESR from
the capacitor spec sheet. Or, you can calculate ESR from the
Dissipation Factor (DF) if this parameter is specified.
Regards,
Jon
