Capacitor Size Matter?
stealth17
Jun 1, 2005
32
Does the physical size of a capacitor matter? Like a tiny 16v 1000uf just as good as a large 16v 1000uf?
audioguru2
Apr 6, 2004
12,022
A larger new capacitor has a better ripple-current rating.
If the capacitor is used as the rectifier filter in a high current power supply, It will have a high ripple voltage across it because its charging and discharging currents are high. A small capacitor will overheat and fail. You might need to use a large capacitor with a higher voltage rating to find one with a high ripple-current rating.
Large old capacitors have about the same ripple-current ratings as small new ones, so don't just select a larger size.
stealth17
Jun 1, 2005
32
cool, thanks. Ive read that its not a real good idea in most cases to go over 150% original capacitance. The voltage doesn seem to matter either. Like I can use a 25v cap in place of a 10v cap without problems. Also Ive read that the low-ESR caps are the ones rated for 105c (usually).
Sound all up to par?
prateeksikka
Jun 19, 2004
736
hi audioguru !
sorry for the interruption but i would say that a surge in the supply would be a more appropriate word than ripple.
Although i agree with u that a large cap has higher rating for surges.
audioguru2
Apr 6, 2004
12,022
Hi Prateek,
Large value capacitors are usually used as filters following a full-wave rectifier in high current equipment. Surges are infrequent but ripple current occurs continuousy, on every half-cycle of the mains. Because the load current is high, the capacitor's ripple current is also high which overheats small capacitors.
prateeksikka
Jun 19, 2004
736
So should we go for large caps specially in filters.
In all ckts i have seen they are generally  the largest components.
A huge giant of a small value. It looks as a pole in a small circuit.
;D
