Capacitor values for opamp circuit and adjustable gain
legoman
Oct 14, 2011
5
Hi all,
Attached is a schematic of an audio op amp preamp I wish to build. http://www.rason.org/Projects/opamps/opamps.htm I will use a NJM2068 opamp enstead of the TL082. I don't have the exact capacitors that the schematic shows. Would there be a significant impact in the circuit performance if I substituted the caps with values say 10x higher (1uF in place of 0.1uF or 100uF in place of 10uF)?
Also this schematic shows adjustable gain by using a resistor on the output. Would it not be more desirable to put the adjustable gain on the feedback resistor?
No, these are not critical. Increasing the input and output capacitors would increase the low frequency response. The one on the + input is to stabilize the voltage divider and a higher value would not change anything.
jackorocko
Apr 4, 2010
1,284
Reason for the pot on the output is to act like volume control. I have seen it on the input and output but never in the feedback loop before. Though I can't give you a specific reason for it.
I have an opinion on the caps, but I don't want to steer you wrong as I really don't know how it will effect the circuit performance. I just know what they are there for. :)
