capacitors as batteries?
donkey
Feb 26, 2011
1,301
ok I will make the first question very simple but there are heaps more. if i was to use a cap as a battery do I need a special circuit?
second is how the discharge is calculated. I know in a battery you use the Mah rating but how do you get that from a cap?
3rd if I use a 1.5volt power source to charge a 16volt cap would the cap output 16volt or 1.5volt?
4th if I leave the cap charged how long til it self discharges... if it does?
thats the start hope I can get some answers
14,293
There is one noteable diffference between capacitors and batteries:
A capacitor's voltage will fall continuously when current is drained from the capacitor.
A battery's voltage will stay at a (more or less) fixed level for some time until the capacity is drained. Then the voltage will fall rapidly. So yes, you may need a special circuit (Google SEPIC converter).
The capacitor equation: C=Q/V
Therefore Q=V*C which will give you a value usually in fractions of AmpereSeconds (As).
Since 1h=3600s, 3600As=1Ah Or calculate backwards to get the required C for a given As and Volts rating.
Honestly: as stated, that's a silly question. Consider any electronic circuit that has almost certainly at least one capacitor across the supply voltage rails. If that circuit is operated by a battery, would the voltage rise above the battery's voltage? Why should it?
You can charge a capacitor to more than Vbat using a step-up regulator or charge pump, but that is way more than just connecting a battery to a capacitor.
It does. How fast depends on the type and quality of the capacitor. An electrolytic capacitor will discharge faster than a foil capacitor.
donkey
Feb 26, 2011
1,301
ok cool all except one point Q=V*C
could you be so kind as to define eachletter for me. c is amp seconds i guess v=volts I guess and q is how long it will take for the item to discharge?
the question I have is how to calculate farad to ah... unless q is farad...
Laplace
Apr 4, 2010
1,252
Q - coulombs (1 coulomb is the electrical charge of approx 6 quintillion electrons)
V - volts
C - capacitance in farads
I - current in amperes (one ampere is the flow of one coulomb per second)
So the more useful equation is I*T=V*C or
I*(delta T)=C*(delta V)
The rate of capacitor charge or discharge (volts/sec) = I/C and is applicable over any interval where the current is relatively constant or can be averaged to a constant.
