Caps in a differential speaker output
jesup
What would be the impact of caps on the output lines to a speaker if it's
being driven in differential mode? Say 10uf in series on each line, with
a 16ohm speaker? I can calculate a normal single-ended RC circuit, but
I'm not sure about this case. Would the low-frequency phase shifts match
or go in opposite directions (which would cause cancellation by the two
drivers at low frequencies)?
Thanks!
Delivered via http://www.electrondepot.com
Electronics Enthusiasts' Community of the Ne
Web and RSS access to your favorite newsgroup -
sci.electronics.design - 448567 messages and counting
Phil Allison
"jesup"
** What a dopey question.
Far as the speaker is concerned, there is only one drive signal - ie that
appearing between the power stages outputs.
Normal RC calcs apply.
The two 10uF caps are in series so equal to 5 uF in series with 16 ohms
..... Phil
jesup
jesup had written this in response to
http://www.electrondepot.com/electrodesign/Re-Caps-in-a-differential-speaker-output-545974-.htm
I know it's probably a silly question to an EE, but I'm a software guy,
and all the examples show no caps for a differential bridged headphone amp
- but the HW engineer likes caps, and dropped them in, and I'm trying to
debug a low-frequency (hard - 10+db/octave) rolloff.
sci.electronics.design - 448671 messages and counting
legg
Thanks!
Attempts to reply normally to this thread seem to bounce.
You should probably be measuring SPL, rather than voltage; but the
voltage will show low frequency reduction from ZRL/xc. A simple
LTSpice circuit is attached for a passive example of varying
inductance. A Dynamic driver is more complex.
Dynamic driver impedance may be complex at the low end; there's
usually a peak as the frequency reduces, before it begins to look
uncoupled. Low power dynamic transducers may be better controlled, as
the air volume moved is small, and efficiency is low.
Your hardware guy's insistence on caps in series with the output may
be misplaced, as these parts will not do much to protect the drivers
from a short circuit, or reduce audibility of start/stop thumps, in a
full bridge.
I assume you're expected to overcome the added loss, in software
equalization of the processed signal. In that case, you should point
out to the hardware guy that you can only do this over a fairly narrow
range of known load LF characteristics - and you that need to know
what they are. That's a hardware measurement issue. If he's been using
16R resistors for loads and measuring the voltage, it's time to get
real.
RL
Version 4
SHEET 1 880 680
WIRE 208 64 192 64
WIRE 96 96 0 96
WIRE 192 96 192 64
WIRE 192 96 160 96
WIRE 256 96 192 96
WIRE 0 160 0 96
WIRE 256 208 256 176
WIRE 0 336 0 240
WIRE 192 336 0 336
WIRE 256 336 256 288
WIRE 256 336 192 336
WIRE 192 352 192 336
FLAG 192 352 0
FLAG 208 64 Vout
SYMBOL cap 160 80 R90
WINDOW 0 0 32 VBottom 0
WINDOW 3 32 32 VTop 0
SYMATTR InstName C1
SYMATTR Value 4E-6
SYMBOL ind 240 80 R0
SYMATTR InstName L1
SYMATTR Value {LS}
SYMBOL res 240 192 R0
SYMATTR InstName R1
SYMATTR Value 16
SYMBOL voltage 0 144 R0
WINDOW 123 24 132 Left 0
WINDOW 39 0 0 Left 0
SYMATTR InstName V1
SYMATTR Value ""
SYMATTR Value2 AC 1
TEXT 358 280 Left 0 !.ac oct 4 1 1000
TEXT 336 320 Left 0 !.step param LS 1 10 2
