Car CD-Player makes noise/doesn't eject CDs
I
infamis
I have a Clarion DXZ545MP car receiver. Recently it does not eject CDs. It
makes a repeated clicking sound as if the mechanism can't move & then gives
up. I opened it up (past the point of no return even though I don't know what
the hell I'm doing; I usually could just disassemble electronics & put 'em
back together and they magically start working again). The mechanism will
eject the CD if I press upwards on that whole gear array. I'm guessing the
sound is the gears slipping or something.
Does anyone have any info on how to troubleshoot car CD players? Or what my
problem could be? I've heard of the term "limit switch" mentioned through
searches on here, but cant' seem to find it on my receiver.
I
infamis
Or any general info about how car radio CD players work (mechanically)?
Ray L. Volts
gives
what
It's possible you have a warped rack gear. Does it get unusually warm
behind your dash (or wherever you have the unit mounted)? If it's under
warranty, put it back to together precisely and clean up any grease smears
you may have created (and/or fingerprints) so as not to invalidate the
warranty and return it. Of course, if you've damaged any tamper-resist
stickers or screwlock glue, you're SOL as far as warranty.
I
infamis
Unusually warm? Not that I know of. I live in Chicago & it's Winter (past
couple days have been around 20 degrees Fahrenheit). Hell, I still don't get
any type of decent heat in my car!
It's far from under warranty; I bought it <used> 2 years ago. And I really had
nothing to lose (reason being is cause 1) out of warranty 2) nothing to stick
into the aux-in rca jacks and 3) radio sounds like crap & don't like it), so,
it's either try to fix it myself or just live without music [which I can't].
The thing is, I take it apart, and just see all these different parts. I don't
know what's supposed to do what. I do know that after I press the eject button
& stick a screw driver under the gears (the gears are like screwed to the
"ceiling" & covered by a plastic cover...so if I press up on that cover),
it'll eject the CD like it's supposed to.
I just haven't found any info on the net on how slot-type CD mechanisms load a
CD (which is the most common type in cars). If I could just find some
graphical representation of how a slot-loading CD mechanism looks, that'd be
really helpful.
Background on my problem:
1. I use my MP3 player 99% of time, plugged into the aux-in of the car radio.
2. Recently had to send the MP3 player back cause of a hard drive failure.
3. So now I'm stuck with the CD player & radio.
4. I load a CD in, play it, but when I hit eject, it makes clicking noises &
doesn't eject. It tries about 3 or 4 times to eject, then gives up with an
error "Error 2" (which in the manual means the CD mechanism is stuck &
cannot be ejected)
5. So now, no CD.
6. I have no antenna on my car, so radio sounds like crap.
7. Now, nothing; I can either take loss trying to fix it myself & failing, or
just not doing anything. I'm an EE major...that is, once I get accepted to my
school of choice, so I know a little about electronics, but recent days have
made me realize I don't know anything :(
K
Ken Weitzel
really helpful.
cannot be ejected)
5. So now, no CD.
Hi...
If you think you don't know anything, then at least you're not
a teenager, eh? :) :)
Dunno how helpful it may be, but a few years ago I had a CD stuck
in a GM cd player. 'twas a burned one, with a stuck on label.
The edge of the label lifted and separated just enough that it
caught on the edge, and no eject.
Discovered the prob by lifting the flap with a pencil, and peeking
inside with a flashlight. Once seen it was easily fixed just by
pushing the edge of the label down again with a jewellers screwdriver
while it was ejecting.
Take care.
Ken
