Cassette Deck Help?
hotdog123
Nov 14, 2018
I picked up a used cassette player and it will rewind and fast forward tapes but will not play them. Any help, Thanks..
Externet
Aug 24, 2009
943
Does the tape advance in 'play' or still ?
Inspect the pinch roller and its drive belt. If advances, check the audio path, amplifier, headphone insertion switch.
hotdog123
Nov 14, 2018
cleaned it with rubbing alcohol, but will not spin when press play. it will fast forward and rewind no problem. Don't know how to check belt. Appreciate your help.
dave9
Mar 5, 2017
1,191
You will have to take it apart and see if the belt is moving both pulleys it's on, or if the motor is stalling, or pinch roller not staying on, hardened rubber or broken spring, etc.
Is the player worthy of buying parts for? You might find something that works, cheap at a garage sale, craigslist, or pawn shop, or sometimes I shop for *local* (pickup) items with no reserve auctions on eBay. Last bookshelf stereo I got for $0.01... but without the remote control, which I ended up paying someone else $10 for. :p
shrtrnd
Jan 15, 2010
3,901
Sounds like the belt to me, you've got good advice already from others here.
My additional input is to use a Q-tip and some rubbing alcohol and clean the tape heads.
The build-up on the heads is another drag on the tape travel, ... although I'm with the other guys
here that you probably need a new belt.
