Celestial HP5188i ctv unidentified parts.
Griff
Celestial Rear projection ctv model HP5188i
NQ821 voltage reg has exploded (STRF6656)
VQ821 transistor is open circuit ( C2655)
VD821 shorted (unknown)
VD829 shorted (unknown)
VD827 shorted (unknown)
R822 measured 5 ohms (unsure if this value is correct)
Can anyone please give me info. on the above parts?
Or maybe even supply a copy of the power supply schematic.
I have been unable to obtain a scematic elsewhere.
Thanking you,
Russell.
F
Franc Zabkar
STR-F6600 datasheet:
http://www.datasheetarchive.com/pdf-datasheets/Datasheets-4/DSA-60158.pdf
2SC2655
From page 14 of the STR-F6600 datasheet:
"Diodes carrying the high-frequency flyback currents (such as the
transformer rectifier diodes) should have a fast or ultrafast
reverse-recovery characteristic, adequate current handing and peak
reverse-voltage rating."
In view of the extensive damage, you may want to check the optocoupler
and any overvoltage protection diode on the secondary side of the
switchmode transformer.
MOSFET current sense resistor?
Thanking you,
Russell.
FWIW, this is the service manual for a Samsung set that appears to use
the same regulator IC:
http://www.eserviceinfo.com/downloadsm/21279/samsung_sp47w3hf1x.html
This forum may have some useful information and a service manual:
http://www.forums.hcsd.com.au/Blah.pl?m-1203453840/
"This PDT6-9D Chassis is for CHANGHONG 'CELESTIAL' RPTV Model DP4338
[should that be DP4388 ???], HP5188i, HP4388i and DP5188."
Local support:
http://www.changhong.com.au/
Celestial Rear Projection Television OPERATION MANUAL for DP4388 and
DP5188:
http://www.eserviceinfo.com/download.php?fileid=28186
- Franc Zabkar
F
Franc Zabkar
Does this help?
http://www.worldwideelec.com/assets/pdf/parts/GT2415~3215PN.pdf
VD821 CHDIO00012 AK03 Diode
VD827 CHDIO00063 W05Z18C Diode
VD829 CHDIO00037 MTZJ24C Diode
VD829 CHDIO00064 W05Z24C Diode
VQ821 CHTRS00008 2SC2655-Y Triode
R822 CHRES00023 MOS2W0R15J Metal oxide film resistor
R822 CHRES00303 RY21-2W-0.15ohmJ Metal oxide film resistor
R822A CHRES00023 MOS2W0R15J Metal oxide film resistor
R822A CHRES00303 RY21-2W-0.15ohmJ Metal oxide film resistor
NQ821 CHICS00057 STR-F6626 IC
Service manual for Apex 24"/32" TV (see page 3):
- Franc Zabkar
Griff
Thanks for all the research and info. Frank.
I have not had time yet to do any more with the set.
Russell.
F
Franc Zabkar
Russell.
It just occurred to me that the part numbers for the Apex TV might be
ChangHong numbers, eg CHDIOnnnnn =
- Franc Zabkar
F
Franc Zabkar
That should have been ...
CHDIOnnnnn = ChangHong DIOde nnnnn
- Franc Zabkar
