HELLO I HAVE 360 CCTV CAMERA BULB NEED HELP
ABBAS123
Sep 28, 2022
25
because i do not know the fuse resistor value i just put 2w 100ohms resistor for testing but i was told you only lights work.if i know the value so its start working with required wats and ohms.
Martaine2005
May 12, 2015
5,318
@kellys_eye thinks it’s a 51 Ohm resistor. You put a 100 Ohm resistor in.
Put two of your 100 Ohm resistors in parallel to give you 50 Ohms.
But as previously stated, if the bridge rectifier is open, it won’t work.
For the last time, check the rectifier (DB).
Martin
Martaine2005
May 12, 2015
5,318
You don’t test a rectifier with AC!.
Use your multimeter on diode test or Ohms range.
Martin
ABBAS123
Sep 28, 2022
25
its require fuse resister that help to correct its function.other value of resister not help out that is why its stop on lights.
kellys_eye
Jun 25, 2010
6,512
You'v put a resistor in and it still doesn't work. There is another fault - a fault that caused the original fused resistor to blow in the first place. READ MY PREVIOUS POST. The fault could be anywhere AFTER the fusible resistor.
Your posts indicate that you do not have the thinking ability or the capacity to repair this device. You don't even read the posts already made - this is not a fault you are going to fix alone and we've tried hard enough to help but you don't seem to be able to understand what we're telling you.
Time to close the thread I reckon?
ABBAS123
Sep 28, 2022
25
i found this picture from internet i think if i put this value of resistance its start working. i know what you mean..
ABBAS123
Sep 28, 2022
25
kindly read that value that shown on picture and tell me which fuse resistance i used that is final help from you....
ABBAS123
Sep 28, 2022
25
please reply and tell me value of fuse resistor that i buy and used.thanks
ABBAS123
Sep 28, 2022
25
just lights blinking nothing else
while put 1/2W resisters 10/100/6.8/ohms
