cellphone battery charger
Phiber
Sep 14, 2012
12
one question please, if I connect a voltage output from a power supply to a cellphone battery, will the battery start charging?
thanks
Young
Feb 6, 2013
47
The power from the source must be exactly the voltage required to charge d phone or what ever,then am sure it will charge but d battery must stil b in d phone and it must still b connected through d charger
Don't do that, the battery could explode! A charger must control the voltage / current delivered to the battery and know when to stop. Charge your cell phone battery inside the cell phone, where the correct circuitry is there to charge it.
Phiber
Sep 14, 2012
12
ok.. noted.. guess I cant use rechargeable batteries for my amp circuit.
thank you very much
Eche
Mar 3, 2013
9
Might I recommend u use a proper charging circuit such as the mcp73861 from microchip. I have a schematic available if needed ...make sure u use exact tolerances as you can destroy a battery or under charge it.
Eche
Mar 3, 2013
9
Phiber..what is the voltage and mA on the battery?
14,487
thank you very much
what rechargable batteries?
what amp circuit ?
you suddenly changed topic in the middle of a different discussion
