charger for Cordless phone battery.
fever16
Mar 12, 2006
41
hi all
iam working on a school LED project.where we need to use a 3.6v 300ma battery(one used in cardless phones).u know cordless phone chargers are dumb type.can u suggest me some good charger for this battery pack.
i don't want  hi-fi type of charger.just simple one which makes the battery last for long times without destroying it.and if it got some indictor it would be great.
thanks in advance
ante1
Jan 24, 2004
4,136
Hi fever,
Welcome to our forum,
You could use an LM317 setup as a constant current regulator at 15mA and just leave it on 24/7!
fever16
Mar 12, 2006
41
thanks ante
is it possible to make some simple moniter type.imean which got atleast indictor(imean lighting up an LED when charging done) using some transistor like..
ante1
Jan 24, 2004
4,136
Hi fever,
You wanted a simple one, just leave it on and the pack will always be full when you need it. If you go for a “ready LED” circuit things starts to get complicated.
fever16
Mar 12, 2006
41
ohh ok then
i did a small search on net and i found below 2.which one of this is best.
http://agendawiki.com/cgi-bin/aw.pl?ChargingCircuits
this one from our forum only.
and this is from groups-google-
what is ur openion abt these
ante1
Jan 24, 2004
4,136
Hi fever,
This is from the LM117/317 datasheet; R1 should be 82 Ohm and you put the pack where it says load! You can power it from any DC-wallwart  9 – 25VDC.  ;)
fever16
Mar 12, 2006
41
thanks ante.i'll go with lm317 based circuit
i dono much abt these abt these rechargbles.but i think ni-cd shld be chrged at 1.5+pack voltage and c/10 of its current rating it.
if it is true then i need 5.1v @ 30ma for 14Hr .
audioguru2
Apr 6, 2004
12,022
I don't know where you learned the wrong voltage formula.
Each cell will charge to 1.4V to 1.5V. Therefore the 3-cell battery will be 4.2V to 4.5V when fully charged.
The LM3117 needs at least 2V across it and the current-sensing resistor has a 1.25V drop, so the minimum input voltage to the circuit is 7.75V.
fever16
Mar 12, 2006
41
thanks for correcting me.
is current calculation is right(c/10 for 14Hrs)
if yes then the final result will be 7-8v input to LM317 with R1 82Ohms resistor.(as ante said) can charge a 3.6v battery pack safely in 14Hrs
audioguru2
Apr 6, 2004
12,022
fever16 said:
is current calculation is right(c/10 for 14Hrs)?
Yes, if the battery is rated for 300mA/hrs.
No. 7V is too low. "The  minimum input voltage to the circuit is 7.75V."
ante1
Jan 24, 2004
4,136
Hi Guys,
Yes 7 volts is too low, that’s why I said “You can power it from any DC-wallwart  9 – 25VDC.”! ;D
fever16
Mar 12, 2006
41
got it.
thanks.
is there any particular formula for this resistor value.
imean in furture if i want to charge packs of 700ma or 800ma etc i need to change resistors too right.
and gyus to charge AA or AAA "single cell" what modification shld be done in  lm317 design.
ante1
Jan 24, 2004
4,136
The voltage drop across R1 is always 1.2Volts (controlled by the regulator), using (I = U / R )you get the charge current.
Example; 1.2 V / 82 Ohm =  0.0146 A that means about 15 mA!
If you increase the charge current to 800mA you need a heatsink for the LM317!
Got it? ;D
fever16
Mar 12, 2006
41
as per c/10 for 14Hr rule,current for charging a 300ma battery shld be 30ma. right.
but in previous post u said 82 Ohms resistor will work.where as it shld be 40 Ohms for 30ma
correct me if iam wrong
iam bit confused ???
ante1
Jan 24, 2004
4,136
Hi fever,
That’s correct for C/10 but I suggested 15mA so that you could leave the pack unattended for an “unlimited” period of time. If you like you can add another 82 Ohm resistor in parallel to have C/10 – 14 h charge. I made a drawing for you, if you leave the switch open its C/20 if closed it’s C/10.
If you don’t need the C/20 setting just omit the switch. The reason for two resistors is that it’s not easy to find a 40 Ohm resistor but two 82 in parallel is 41 Ohm and that is just fine. 8)
fever16
Mar 12, 2006
41
cool.
thanks a lot ante.
tomorrow i'll get some resistors of different values.so that i can make it variable.
imean 15ma-c/20
          30ma-c/10 for 14Hr
          60ma-c/5  for 7Hrs (ofcourse not preferable)
thanks once again.for helping me
u ppl are just really amazing .  :-*
