Cheap marginal noise cancelling headsets
Don Taylor
Since the subject of noise cancelling headsets has come up here a
number of times recently I thought a few folks might be interested.
Grocery Outlet, a chain store spread across the U.S. that specializes
in closeouts and returns, got a shipment of Phillips HN050 noise
cancelling headsets in. $50 suggested retail, $10 at Grocery Outlet
while they last. Some local stores sold out in less than a day,
but others still had a few on the shelf days later.
Specs on the back say
Active Noise Attenuation 50-1500hz
10dB at 300hz
The ones I got were the "wrap around the back of the head with
little outside the ear pads." There was one other model that was
an earplug version. I didn't get one of those, maybe I should have,
didn't check the specifications or model number, definitely should
have. It was also $50/$10.
So I bought two and tried one on my usual test case, street noise
and the roar inside city busses. In my opinion there is a definite
but barely audible reduction in the low frequency noise with these.
If I'd paid $50 a copy for these I'd be pretty upset.
Comparing these to failing memory of my really old ANR, if I remember
correctly, noise cancelling headset that I paid about $100 for maybe
ten years ago, and which went intermittent and I haven't gotten
around to fixing, made me think that the Phillips were substantially
less effective. I seem to remember the ANR almost completely cutting
the roar inside the busses.
Unfortunately, when it cut all the roar I then found I had to listen
to fifteen ongoing conversations that had been previously masked.
So, finally, a question I've never been able to get what I thought
was a really dependable answer to. If processing power went up say
twenty fold, sample rate went up twenty fold, atod had four more bits
of accuracy, is there some fundamental reason we couldn't cancel the
speech up to say 4500hz and increase the dB reduction? Or is there
some wall that the current specs are up against and it would require
vast increases to get even modestly better results?
Clifford Heath
Wavelength of sound? 3" at 4500KHz... Perhaps with an
in-ear transducer... Interesting feedback loop nonetheless.
Joerg
Hello Don,
Whenever I tried noise cancelling headsets I was a bit disappointed.
They only worked well in airplanes on long hauls where the pilot doesn't
touch the throttle for long periods of time.
Regards, Joerg
