roughshawd
- Jul 13, 2020
- 618
- Joined
- Jul 13, 2020
- Messages
- 618
I have seen a lot of pucky on boards, and I also have removed some things I thought were melted holders or clamps or supports that I thought got hot. I fixed my battery issue on my SD-1 Synth and put a battery holder on it so I don't have to do any soldering when I change the battery. The main board had the connecting copper layer peeled off before the diode between the + battery and the diode from amature soldering techniques...
So I bent the + through the hole pin, of the battery holder outward, to reach the diode, effectively bypassing the bad part of the board. I also had to jumper the ground side of the new battery holder becauseof the same kind of problem, but I used the hole for a stabilizer on the battery holder mount.
"Now I'm not knocking engineering, but how many times have I told you guys about using the contacts as mounts?"
This problem, on this device, is the ultimate conclusion of this ignorance! What I want to know is what kind of glue I should use to permanently mount the battery holder on the board, just in case this problem comes back in the future!!!???
(I found a tube of adhesive from the 60's called "Liquid Nails" on a back shelf in the shop and so far I am thinking -> 'no heat, drys over 24hrs, causes cancer, has emergency number for inhalation on tube, needs kneeding to soften product, and holds battery mounts securely on broken sythesizers.) And It doesn't require a sign that says...."CAUTION - WE USE LIQUID NAILS HERE, THAT IS KNOWN TO CAUSE CANCER IN CALIFORNIA IF ITS INHALED".(NOTE - contains Crystalline Silica)
