Cheap PCB prototpes?
Robert Baer
Most especially prototypes made with "non-standard" material, EG:
20mil to 31mil material.
Ideas? References? Approx pricing for 1-2 boards?
Martin Riddle
I think 31mil is a standard size.
Size and # of Holes needed.
Probably around $500 from the big guys. Less thru the pools.
Cheers
P E Schoen
"Robert Baer" wrote in message
Who? Where? *REFERENCES*?
Thanks for wasting time with NON-information.
Your time is still (again?) off by one hour.
There is a guy I use for "quick and dirty" prototypes, but probably just
standard 1/16" FR4 and no PTHs. But he might be able to make what you need.
I made a calculator based on his formulas, so you can figure out what he
would charge. I will be getting four 1.5" x 2.5" double sided boards for
about $32 including setup and shipping.
http://enginuitysystems.com/files/Atlas_PCB_Calculator.xls
Paul
Goddamnit, just give me references and *I* will find out from THEM
what THEIR criteria WRT pricing.
I use different suppliers for different sizes. Some are cheaper for smaller size and some for bigger board.
Being an asshole, you would bitch if i required YOU to do screening
(ie: any WORK).
So do everybody else here. That's why they invented Google.
Robert Baer
PCB prototypes everywhere depends on size.
You are welcome. Nondeterminate question get nondeterminate answer.
(ie: any WORK).
Try http://www.youpcb.com
for 5cm x 5cm 10PCS prototype, 1.6mm, FR4, 1oz copper thickness, any solder mask color, white overlay, price is $29 shipped by USPS (if you are in USA).
Same standard but 10cm x 10 cm, $44 shipped by USPS if you are in USA.
I have used them a few times, very good service, down side is they only take Gerber files. However their order status has lots of real time details.
Good luck
Just did a online quote on http://www.youpcb.com
10PCS, 10cm by 10 cm, 24mil thickness (0.6mm), it will be $41 shipped (if you are in usa). Cheaper then 1.6mm, I guess the shipping weight is less so it is cheaper.
My micro layout, with via, is bigger than 10x10. Even a 20 pins FPC socket is bigger than 10mm. What else can i put on the 10x10?
Robert Baer
Cheers
Check; found that PcbCart allows a wide range of thicknesses - very
useful.
Board as a rather huge number of holes (4) and the largest dimension
is giant (less than 1.5 inches).
PcbCart quoted a price competitive with ExpressPCB (under $100).
For a onesie, this is a very good start, as ExpressPCB is like Ford
when they first started ("you can have any color you want, so long as it
is black").
Does anyone know if they will score a panel (V-cut) from the 10cm x 10cm
board ?
I need .7" x 1.1" boards, a 10x10cm panel would hold lots if they will
score the pcb for the same price.
Pcbcart.com would do it with minimum cost (or none, i don't remember). I ordered a few hundreds from them before.
But there are cheaper places that would cut it up nice for you.
I remember I have done it once, but not sure if there are additional cost or not, let me check my orders when I get back home.
H
hamilton
I registered with youpcb.com.
The order form shows Board type[?] OIndividual oPanel, but I can not
select panel.
At the top of that page is says: Order type _Prototype _
So I guess that I can not order a panel from the Prototype menu.
And the Instant Quote button does is broken !
[Controller doesn't
exist/home/tiao/public_html/youpcb/Controllers/index.php.gds.php]
