Cheap potting alternative
Larry Kent
Is it possible to use epoxy or polyester surfboard resin for potting
audio fequency PCB's?
How about the crystal epoxy used for encapsulating insects, etc?
Any other low cost alternatives, aside from flexible rubber/silicone?
Many thanks,
Larry Kent
D from BC
Many thanks,
Larry Kent
I tried a solvent based 2 part epoxy mistint sold for cheap at a paint
store.
It only dries in thin film as it's supposed to.
I tried potting and it was still gooey after 1 week.
The gooeyness could be from solvent getting trapped by the skin that
forms. iows.. The epoxy paint self-seals extending the cure time.
That or the paint was overtinted. Was blue.
So don't try that.
Solvent based epoxy paint is different than 100% solids epoxy or the
type used for glue.
Maybe try 100% solids epoxy for floors??
K
Kevin McMurtrie
Many thanks,
Larry Kent
Don't use general purpose epoxy or polyester! Some formulas will sweat
compounds that are corrosive and conductive. Formulas meant for fiber
composites can get so hot in large volumes that they'll incinerate
themselves.
You can buy electronics potting compounds at online electronics stores.
Conformal coatings can provide water and dirt resistance without making
the circuit impossible to repair. Aerosol cans of pure urethane from a
hardware store seem to work well too. I haven't seen urethane attack
anything yet and adhesion is pretty good.
Avoid 3M Scotch Weld Epoxy Potting Compound because it has extremely
poor adhesion. It forms beads in thin films and it cracks away in thick
films. Either way your project is ruined.
D Yuniskis
Hi Larry,
What are your *goals* in potting the circuit ("protect" IP, prevent
tampering, environmental extremes, etc.)?
Also, what other criteria affect your choice of compounds (e.g.,
thermal properties, weight, etc.)
Larry Kent
You can "stretch" epoxy used for potting, and save quite a bit of
money, by loading it up with a filler before pouring. I've
encapsulated small circuit boards in TAP Plastics' slow-cure marine
epoxy, mixed with fine dry sand... cheap and effective, if rather
heavy and prone to settle out during the curing process. Glass
microspheres are much lighter, don't form as hard a matrix, and are
rather more expensive :-(
A friend suggested surfboard epoxy, but with the foam powder that they
use for ding repairs mixed in. Lighter than sand, athough not a tough
I suppose. The "give" it provides apparently cushions the parts during
curing.
Does that sound feasible?
Larry Kent
Dr. Heywood R. Floyd
Polyester resins often heat up a lot, and shrink, when curing. That's
not necessarily a problem when fiberglassing a surfboard, but it can
put a serious stress on components during encapsulation - might crack
'em loose from the board in a really severe case. I believe this
tendency can be reduced somewhat by using a slower curing cycle (less
catalyst per amount of resin).
One can also reduce this issue by conformally coating the PCB first.
That way, no potting compound migrates between SMT parts and the PCB ,
which is where these shear forces occur.
Some of these resins remain somewhat sticky when cured, and need a
topcoating or upper layer containing a surface-hardening agent or wax.
Fine grain fiberglass "powder" (shards) makes an excellent filler as it
also makes the media a better thermal conductor.
I've
One can go to nearly any automotive machine shop, and can usually buy a
handful (or a quart sized volume) of glass beads used for grit blasting
purposes. You need to buy it from a newly opened bag that has not been
added to the grit blaster yet.
Joerg
In the olden days potting tar was used, and often still is. Very cheap
but I wouldn't know a distributor anymore. However, it is not very
pretty if that's what you are after.
