CHEAP Serial bus, control 200 devices, 50 meters
Rich Grise
If I roll my own, I also need not just a bus, but a protocol to address
and communicate with the i/o modules.
I just wanted some suggestions. But, I wonder if I can't roll my own for
$100/machine.
Then, of course, the question becomes, what exactly _are_ these machines?
Sewing machines? Bird feeders? Looms? Punch presses? Chinese Typewriters?
What's the layout of your plant? What are you making there?
Have you decided what you actually want communicated, or are you even
looking for suggestions for that?
We thirst for more information, like what's this 16-input, 16-output
device? A ROM? A PLC? A Kiln?
Rich
Armin Steinhoff
Brook said:
Dave VanHorn wrote:
Sorry, I meant 100k bits per second.
.... and you mean realy "200 devices in a range of 50m" ?
Must some kind of NANO technology :)
Armin
Rene Tschaggelar
Nico said:
There are some very space efficient TCP/IP stacks around. I've noticed
its quite hard to put a reliable communication protocol together. It
takes some serious thought on fault detection, re-transmitting lost
packets, time-outs, packet re-alignment, etc. So why try to invent
something new if you can use something that already exists?
Very efficient ?
TCP/IP allows to transmit block of 2^32bits in random
packet order. To as many as 2^32 devices. It adresses
2^16 different ports per device. This is huge overkill
when the packetlength is shorter than 250 bytes, to
less than 255 devices.
Rene
Rene Tschaggelar
Brook said:
You're right, that was unclear. I meant 100Kbps. I realize the protocol will
have some overhead, and that's fine. And I could maybe get by with a lot
less. For example, I have to feed a powder from a loss-in-weight feeder. The
PC has to control the feeder motor and monitor the weight. I have different
options for controlling the motor. If I use stepper motors and try to
control every step from the PC, I need more speed. If I just tell it
start/stop, then I don't need nearly as much speed.
Ooohhhh, nooooooo.
Never attempt to control a process with a PC. A PC is not
reliable enough. Nor can a timing be guaranteed.
A floting point error in some unimportant display routine
can stop the application.
You always have to consider the PC stops working. The
motors running keep running. The heaters keep
heating. Leave the process control to embedded devices and
feed them from the PC. Such a system has to be and stay in
a safe state when the PC fails. Whenever that may happen.
This means the PC tells a controller to do something and
then leaves this device. You may also have to design failsafe
states, meaning when the controller was not updated for
however long, it goes to a certain state. EG heater off.
Rene
N
Nico Coesel
Rene Tschaggelar said:
Very efficient ?
If you use a standard ethernet chip, it will do most of it for you at
high speed using standard cabling, standard hubs / switches, etc.
Besides, the more advanced IP stacks will collect a number of packets
(nagle algorithm) for a given target and send them as one packet to
reduce overhead. If you send a lot of short messages to a target from
-let's say a PC- in a short period, the target will receive 1 or more
long packets.
Armin Steinhoff
Brook said:
Rene Tschaggelar wrote:
Thanks Rene. RS-422 seems like a good option for the bus.
RS-422 is not the right choice for a BUS. RS-422 can be used for a
one-to-one (or one to many) communication structure.
Use RS-484 ... or simply CAN and you go with a standard.
Armin
Rene Tschaggelar
long packets.
Yes, the ethernet chip does up to the IP level. Meaning
1500 something bytes, no ports, no retransmit, no reassembly.
It may depend from which platform you look, from an 8bit
micro TCP/IP is a heavy burden. I'd possibly prefer UDP
if it had to be. The random transmissions have to be
controlled somehow to reduce collisions. But a master-
slave setup should do that nicely.
Rene
F
Fred Bloggs
Armin
What's the matter with industrial ethernet, using that cheap 8051 Rabbit
thing with TCP/IP stack- proprietary boards should come in at <$10 in
quantity- just tell the nodes to shut up unless spoken to- no
crashes/clashes or whatever they're called- cheap UTP cabling.
Jerry Avins
Ooohhhh, nooooooo.
Best advice so far!
Jerry
Rene Tschaggelar
What is wrong with implementing a master/slave system onto
a one-to-many bus ? RS422 doesn't require switching the
direction. An RS232-to-RS422 converter takes 3 chips and
fits onto a square inch. I'm not familiar with RS484, a
search turned up only fluff.
CAN is a fast bus but is limited to 6 byte messages or so.
The last time I looked at it, there was no provision for
longer packets.
The command set has to be designed to fit the application
in question. I doubt the car industry has a fixed commandset
and all CAN subsystems are compatible across the maufacturers.
Just guessing...
Rene
Jerry Avins
longer packets.
Just guessing...
Rene
Years ago, I implemented an RS-422 multidrop system for Siemens Energy
and Automation, complete with a proprietary signaling protocol designed
for robustness in an industrial environment. The arrangement used a star
of buses, with repeaters to extend buses as necessary. Each transmitter
signaled to as many as 24 receivers, all of which listened for its
unique address. The selected device signaled back full duplex by making
its normally tri-stated transmitter active.
The signal protocol sacrificed efficiency for generality. Each message
included a preamble to guard against framing errors, a length byte that
didn't count these overhead bytes, a CRC-8 "checksum" for the address
and length, and a CRC-16 "checksum" for the message. Messages could be
from zero to 255 bytes. Byte parity was not used, so all 8 bits were
significant.
Messages were composed in ASCII to simplify analysis of data traffic.
Logging was as simple as letting a printer eavesdrop. I strongly
recommend the practice when time permits. There's a simple routine at
the end of http://users.erols.com/jyavins/tantrum.htm for outputting hex
data in ASCII. (68HC11 assembly code)
The prototype system was logging trouble-free hours in a power plant
when I was detached from the project. I know that the product line that
the signaling system was developed for didn't go into production, but I
heard that the system was under consideration for another application.
My guess is that they used Profibus instead.
Jerry
N
Nico Coesel
RS422 is current loop and therefore only usefull for peer-to-peer
connections. RS485 is a differential interface which may be
implemented as a half duplex bus or a separate transmit and receive
pair for a full duplex peer to-peer connection.
Chris
Logic level.
I don't need it enclosed. I have 120v AC, but I expect the devices would run
on 5-12v DC.
Good question. :) I can be married to it. I would roll my own, but that
depends on how easy it is. If the chips exist that will do most of the work
for me, then I would roll my own. Then it depends on how much money will it
save me over the store-bought alternatives. Looking at the prices I'm
finding, and the prices you listed below, it's looking more and more like I
should build my own.
If I roll my own, I also need not just a bus, but a protocol to address and
Thanks Chris. That's a good suggestion. That's just the type of info I was
looking for - a low-end solution. Now I wonder if there is a lower
end?
Hi, Mr. Stevens. Stirred up a hornet's nest here, I guess. Thanks for
providing some more information on your project.
Altogether, I'm still wondering if the Stalinized total centralized
control model is the way to go, particularly with a PC. Some posts
below have commented on the issues connected with doing things that
way.
What I'm wondering is, if you are going to need some intelligence to
send and receive serial communications, why not also put that
intelligence to work doing some of the programmed sequence of events
you're running on each machine? Using your example of the powder
feeder with scale that has TTL output, why can't you just tell your
distributed intelligence to start the cycle? It then turns on a relay,
and then accepts data from the scale until the weight comes to a
certain amount or timeout, then turns the relay off. That way, the PC
can just periodically poll the distributed controller to ask how things
are going. And given the fact that most scales only give a couple of
readings a second, it shouldn't be that hard for your distributed
intelligence to keep up.
Anyway, that's the way it's commonly done. Frequently, that
distributed controller will be a PLC in an industrial environment.
That's because the programming is straightforward, all I/O are
electrically isolated from the PLC as well as the comm port (which does
wonders for reliability), and PLC manufacturers are committed to
keeping a model in the market for a long time (otherwise they lose
market share). That makes pop&swap maintenance possible by
non-technical people. In other words, the project designer isn't
married to the project for the rest of his life.
If you want all TTL I/O, the PLC becomes a little problematic. You can
purchase add-on modules which will give you that, but it will increase
the cost more. They're not made that way. That would tend to lead you
in the direction of a Single Board Computer, which does have TTL I/O
built in.
Whether you decide to go with distributed or centralized control, a
good inexpensive choice might be the Rabbit RCM2020 Rabbit Core Module.
It gives you up to 40 I/O, and has good serial comm capabilities.
Best of all, they're $31 each in 100 quantity. You could make a small
surfboard with sockets for the RCM2020, and put a good 5V regulator and
isolated RS-485-to-TTL converter on the board. That will fill your
minimum system definition without breaking the $100 per station barrier
(after the first working unit).
Either way, you should start out with the RCM2000 development kit for
$169 USD. It gives you everything you need to get started programming,
including a development board, power supply, cables, and Dynamic C
software for free. Dynamic C is optimized for realtime control, and
might work well for your application. Actually, the free software that
comes with the development kit is the best part of the package.
That will go well with the multi-port PC RS-485 serial board I
mentioned in a prior post. If I had to do just this, I would get a
board that has timers and DOS drivers with Turbo C++ 3.0 for DOS
examples, and do the PC program in Turbo C++ for DOS and Greenleaf
CommLib for DOS. DOS is helpful because you don't have to worry about
most of the other things that are going on with a Window$-based PC. It
isn't easier when you add in a user interface, but you get better
control over what's happening.
You've got a good amount of work ahead of you if you choose this route.
Be careful about ground loops in large systems -- they're a major
cause of those dreaded system anomalies that keep you up late at night.
Try to keep your RCM2020 or whatever controller as electrically
isolated from the rest of the world as possible, use the best power
supply you can afford, and be careful with switching inductive loads.
They can cause EMI-RFI problems which can upset the apple cart, too.
Good luck (which is the residue of hard work)
Chris
John Larkin
I need PC control/automation of:
200 machines
Each machine needs 16 logic inputs and 16 outputs
Line lengths may be 50 meters
I want a serial bus to connect the i/o devices at each machine with the PC.
This is to reduce the wires needed, lower costs and simplify design.
It is not a noisy environment. No welding, for example.
I don't need more than 100kHz speed, and might get by with even less.
I don't need environment protection. The devices can be just a circuit
board. It's indoors, not a washdown area.
I don't need super high reliability. It's not a life support system.
Cost is a major concern.
I've been looking at some industrial bus options. Either they cannot handle
200 devices, cannot handle 50 meters, or are very expensive (x200). But,
there are so many, I don't know them all, and maybe some can be modified to
do what I need that I'm not aware of.
Can anyone offer a suggestion or alternative?
I'd suggest either...
RS485 in reasonable local clusters, with a tree structure of repeaters
to localize faults and keep the fanout legal.
or
Ethernet, using the Lantronix Xport modules talking serial to a small
local uP, or a Rabbit module to do the whole thing on one little
board. The Ethernet hubs and cabling are dirt cheap, and it would be
fast and very fault tolerant. You could do the whole thing for well
under $100 per node.
John
K
keith
What's wrong with having 200 devices withing 50 meters?
Jerry Avins
Let's see ... 200 drops in 50 meters ... on average, the drops are 25
centimeters apart. If the controller is in the middle and the bus goes
out in several directions, the drops may get as far apart as a meter on
average. That's still a pretty tight cluster of machinery/
Jerry
Jerry Avins
Both RS-422 and -485 are differential voltage. A transmitter enable is
optional with RS-422, but required on RS-485. I wrote of RS-422; that's
how the project started. We switched to RS-485 when we built the prototypes.
Jerry
K
keith
Not nano, though. I wuz thinking more "within" 50m.
Armin Steinhoff
Please differenciate between the production costs (<10$ ??) and the end
user price ... or do you are tkinking about GPLed hardware? :)
Armin
in
Armin Steinhoff
a one-to-many bus ?
If a strict master / slave relation ship is OK ... why not.
Oh ... I just hit the wrong key. RS485 is the correct one.
8 bytes of data ... there is room for are 32 input and 32 output signals
and this is more than requested.
longer packets.
Longer messages are handled by CANopen ...
Just guessing...
No ... there is a real confusing set of incompatible layer 7 protocols
used by the car industry.
