Cheap way to desolder SMD capacitor?
Ross Herbert
Anyone know how to desolder SMD capacitor without having desoldering
station?
SMD capacitor Picture
http://eddie.dyec.com.tw/diy-products/caps/cap_image/panasonic_cap.jpg
The only cheap way I have used is to destroy the cap by cutting it
down to the base with diags and then applying heat from a soldering
iron tip while gently levering both sides in stages with a scalpel
blade.
If you have a fine jet hot air gun you could use that.
Dr. Anton T. Squeegee
station?
I run into those constantly in some of the radios I service. I find
that a set of Pace Hot Tweezers works wonders.
Remember: The proper soldering/desoldering tools are an investment,
not an expense.
Happy tweaking.
David C. Partridge
Hot air paint stripping gun - not ideal as the air flow rate is rather high
(risk of blowing parts off the board as the solder melts) and too large an
area heated typically, but if push comes to shove it will do the job.
Arfa Daily
high (risk of blowing parts off the board as the solder melts) and too
large an area heated typically, but if push comes to shove it will do the
job.
They usually come out easily enough, if you heat what tiny piece of the leg
is visible, one side at a time, and add new solder. Use a reasonable power
iron eg 30-40 watts, and fitted with a pointed tip. The existing solder
will then melt right under the leg, and you can lift up the first side
simply by leaning the body of the cap over a few degrees. Then go back to
the other side, and reheat its leg. This one will usually then allow the cap
to lean over far enough the opposite way, to get that leg right off the
board. Back to the other side, and one more application of the iron, will
fetch that leg off also. Clean up the pads with desolder braid. Make sure
you noted carefully which was the " + " side of the cap, before fitting a
new one. Place new one on pads, and hold on with your index finger tip.
Apply iron to one side, and hold it there for a couple of seconds. The
tinning on the pad and leg, will hold the cap 'tacked' in place. Now heat
the other side, and apply a tiny amount of fine gauge solder. Finally,
reheat the first side, again applying solder.
Whilst using a heat gun is ok if you're experienced, I would caution against
it, if you're not, and don't want to see a neat pile of other surface
mounted components that were nearby the one you wanted off, all sitting on
your bench ...
Cutting the cap is also a workable method, but be careful if you do, that
you don't sqash the bottom of the cap too, and tear the legs, complete with
pads, off the board. I would agree with Anton above, who said in his post
that good soldering equipment is an investment, but I also completely
understand that this is often not a practical proposition for the
non-professional, who'd only going to use it once a year.
Arfa
Jason D.
Pain in A$$. I had to deal with 50H82 toshiba replacing most of it
just with my adjustable weller. I don't get that, this metal box has
plenty of height space for standard through hole capacitors which I
did instead. Just to get color back per the toshiba bulletin.
Cheers, WIzard
TomWTexas
station?
http://tinyurl.com/rvxnn
I had a TV tech show me a way to remove these type caps from
mitsubishi circuit board. He mashed the "can" with a pair of needl
nose pliers and twisted it off the board. The two "leads" were lef
soldered to the board. Each "lead" can be desoldered individually.
TO
Arfa Daily
Cheers, WIzard
It doesn't always work. though. Many Sony CD players of a few years ago, are
fitted with a servo pcb on the bottom of the deck, which employs several of
these exact type sm electros, which in the case of the Sony, leak. If you go
ahead and replace them with standard radial lead types, the board will never
work again ...
Arfa
Jason D.
work again ...
Arfa
I understand, I made sure to use decent caps that has best ESR. The
new SMD ones we have here is also poor on ESR.
Cheers, Wizard
Chris Jones
station?
I would use two soldering irons, one in each hand, to heat both pins at
once. For at least one of the irons, an Antex brand might do well, they
are cheap and much better than most of the irons at that price. You might
already have a good iron to use in your other hand.
Chris
