Cheapo DMM
  • Thread starter Watson A.Name - \Watt Sun, the Dark Remover\
  • Start date
W
I stopped by harbor Freight Tools last wk and bought a Cen-Tech DMm for
$3.99, which is even cheaper than the ones I got thru the mail. And
that's with a 9V battery. I like the separate on/off switch, because
you don't have to crank the rotary switch halfway around to turn it off.
I opened it up, and it's COB, really cheaply made. but the test leads
are bertter than the ones I got by mail, which had test leads that were
open - the wire was defective.
I found this auction on Ebay. He's probably going to Harbor Freight and
buying them for $3.99, and reselling them one Ebay for twice that.
<http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=4558
178849&category=43989>
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
John Ferrell
They seem to be pretty accurate. I bought several last Christmas for
folks that never seem to have one. I also placed them wherever I might
likely need one.
ehsjr
They are great for what they are: kick around, who cares if
it drops out of the tree and busts, throw one in the tool box
or the glove box, meters. I bought some on sale for $2.99 (no
typo, *2*.99). On plain DC circuits they are fine, but don't
trust them with noisy DC. I run ~50 ns ~ +35 V pulses at about
1Khz into a car battery (used to start my generator). "Real"
meters see 13.8 V - the Harbor Freight sees ~ 19 volts. Haven't
noticed a problem on AC, ohms or current. They have a Hfe
position, which I haven't tried.
And it's a cheap source for a DPM.
Ed
W
likely need one.
Since they're COB, there's not much you can do to mod them. You can
take it out of the case and put it in a panel, or something like that.
Maybe use the LCD for another project. Oh, and if you need a pair of
test leads and a spare battery for your Fluke, you can't beat it. ;-)
Si Ballenger
I bought some of the earlier ones for $2.99 during a harbor
freight sale. They are pretty rugged and work well for most of my
needs. Would be good for classes or group projects (boy scouts,
robot clubs, etc) where each person could have their own meter.
The thing I miss is a beep function when checking continuity.
They have another version with the beep for a few dollars more.
I've see them sold on the net as high as $18.99. Google for 830b
meter.
W
What're you doin' up in a tree, Ed??
Ed
I've noticed that the HP 3478A bench DMM that I recently bought is
acting weird when I switch on a compact fluorescent desk lamp that sits
next to it. The DC range goes higher, especially at low DC voltages.
It's hard to tell, because it changes with where the test leads are,
etc. Some of it might even be coming from the lamp, back thru the power
strip, and into the DMM. All I know is that when I turn the lamp off,
it settles down and gives accurate readings. I may have to go back to a
regular blub. But I sure do like the desk lamp. It has two 13W "PL"
CFL tubes and puts out a lot of light. Only $25 at OSH.
W
Si Ballenger said:
8
meter.
Some seller on Ebay sells them for really cheap, and then nicks you for
ten or fifteen bucks shipping. I've read some Ebay disclaimer that says
they get complaints about sellers that overcharge for shipping. But
they basically say buyer beware, take your biz elsewhere, they won't do
anything about it. One thing I noticed is that these cheap meters all
have AC ranges that go no lower than 200VAC. I wonder if that's because
they want to cut corners and save money on switches, etc, or if it's
because too many people put the meter on 120 or 240VAC and burn out the
lower ranges.
Chuck Harris
CFL's send a bit of asymetrical, approximately 100KHz RF down the
power cord. They can be exciting "friends" to have on a test bench.
The only time I have noticed my HP3478A being affected is on the low
AC ranges, if I drape unshielded test leads over the lamp. It adds
50mv AC to the reading.
On even the lowest DC range I notice no effect from draping the test
leads over the CFL.
I tend to use shielded test leads with my meters. The best arrangement
I have found is a Pomona bananna plug to BNC adapter and a shielded Pomona test
lead set with RG58 and a BNC connector on it. I have used the Pomona shielded
test leads that go straight from the bananna plug to the coax to the test
connectors, but I don't like them because the outer insulation on the RG58
pulls away from the bakelite bananna plug, and reveals the shield.
-Chuck
OBTW, if you have the 50/60Hz switch in the wrong direction, you will
see some 60Hz sensitivity on the low DC ranges of your meter. Are you sure
when you changed it a while back, that it was really in the 50Hz position?
W
leads over the CFL.
-Chuck
position?
Yeah, it was in 50 and I changed it to 60Hz. BTW yesterday I got my
*real* (as in HP p/n) 3478A Service Manual. I bid on it on Ebay and got
it for $10 plus shipping. My 7th or 8th manual purchase from Ed
Matsuda, but first from him on Ebay. You remember the 'Tucker's tax on
shipping' debacle I went thru in April. Well, those Ebay/Paypal SOBs
did it again! Their checkout charged tax on shipping! Ed said he
didn't know how to change or correct it, so he sent the diff in change
in the package. I swear on a stack of bibles! This godforsaken DMM is
JINXED!
Chuck Harris
Watson said:
position?
JINXED!
Try putting it back into the 50Hz position, it is possible that there
is something wrong and an earlier tech "fixed" it that way.
As to eBay/Paypal and taxing shipping: logon, and vent your frustrations
in their direction. They want to do things correctly, but like everyone,
they make a mistake or two along the way. Sales tax rules differ from state
to state. Some require tax on services, some don't. They must have CA in
the wrong column. If you don't tell them, it might be a really long time
before they get it in the right column.
-Chuck
Michael A. Terrell
lower ranges.
The meters appear to be designed for beginner or casual users that
would have little or no use fro the lower ranges like the clamp on AC
Ammeters with a voltmeter function. As long as the HVAC guy or
electrician can read something close to 24 volts, they are happy with
the 200 volt range.
Joel Kolstad
anything about it.
Many people get bit ONCE by the guys who clearly view "shipping and handling"
as a profit center, but after that people learn to read the sellers' policies
carefully! eBay certainly isn't the only place where this game goes on -- the
"New York mail order photo equipment" places were notoroius for years for
low-balling the advertised price of a camera and then charging you something
ridiculous in shipping.
On the other hand, some places go to the opposite extreme -- Amazon.Com has
"free" shipping on most orders over $25, but clearly they have to recover
those shipping costs somehow, right?
I think it would be hard to eBay to police this in an automated fashion --
with all the various shipping companies, insurance options, destinations,
etc., they'd almost have to employ a bunch of people whose sole job would be
to look at each and every auction and decide if the S&H was "reasonable."
they want to cut corners and save money on switches, etc.
I figured it was becasue they wanted to use things like silicon bridge
rectifiers and still be able to claim some reasonable percentage accuracy, but
I like your idea about people burning out the lower ranges even better.
---Joel
ehsjr
:) Nothing, for a while. I kinda "donated" a
hamstring to the cause at last Sunday's softball
game. But a treehouse, night camera, antenna, listening
device, whatever zany experiment sometimes belongs
in a tree.
Bummer. Maybe the lite belongs up in a tree. :)
What is OSH?
Ed
W
Joel Kolstad said:
in message
For years, I read that Amazon's biz model was to gain market share by
cutting profits to the bone, in other words sell at a loss at times.
And with gas at $2.40 a gallon and rising, it seems to me that free
shipping is asking for trouble. It would make better economic sense to
have a shipping surcharge to pay for the rising fuel costs.
"reasonable."
I've never sold, but it seems to me that if they required the seller to
fill out a form, with certain choices and/or dollar amounts, then it
would take care of the automation aspect.
Another consideration is that (at least within Calif), the less the
seller charges for the product and the more he charges for shipping, the
less the state makes in sales tax. So it would behoove the states to
make sure the sellers don't abuse this.
[snip]
W
ehsjr said:
Watson said:
Watson A.Name - "Watt Sun, the Dark Remover" wrote:
[snip]
Need a loooong extension cord. You'll see that a lot in two weeks when
the latest H.P. book "Half-blood Prince" comes out. Kids will spend all
their time reading it in their treehouse. ;-)
What is OSH?
http://www.osh.com/Cultures/en-US?ft=true
I always wondered what would happene of you screwed around and did
http://www.osh.com/Cultures/en-US?ft=false
or whatever. Tried it, and it didn't seem to make any diff. :p
Same as http://www.osh.com but it just automagically puts the rest in
there for you.
Chuck Harris
Where are the CFL tubes relative to the solid state ballasts?
If they are running the usual 100KHz SS ballasts down in the base,
and trucking the wires for the CFL tubes a dozen inches to the lamp
head, that is likely to radiate much more trash than the usual
CFL replacement for an incandescent bulb.
-Chuck
W
I haven't pulled one apart yet to find out. BRB...
Well, I pulled the base off one, and found two regular laminated E-I
'transformer' ballasts in the base. Three wires (not twisted) up thru
the gooseneck to the tubes. No electronic ballast. But the waveform of
the AC is still noisy because the tubes breakdown at some high voltage,
so relatively quick risetimes. I saw no caps at all in the base. To
help filter some of the noise, I may get a X2 or Y2 rated cap and solder
it across the AC line in the base. It's zipcord with a two pin power
plug.
Chuck Harris
plug.
Interesting. I have both a CFL (in a luxo lamp), and a regular fluorescent
(in a Luxo magnifier) on my bench, and neither bother my HP3456A, or my HP3478A
in the DC positions. They do bother both meters in the AC position, but that is
expected.
I have to wonder if the 50/60Hz switch is working properly on your meter. What
you are describing is exactly why that switch was put there.
-Chuck
ehsjr
Just got a new Harbor Freight flyer in the mail - they are on
sale again for $2.99.
Ed
W
First time I'd been there in years.
Probably be years before I go again. :p
