Hello folks, after weeks of none stop working I finally got round to constructing the power supply.
I purchased a chassis mount transformer with 240 vac primary with 0 6 0 6 twin secondaries at 50 va 4.7 amp.
The 2 outer wires were used for 0 vac and 12 vac with the 2 inner wires linked together for the 6 vac centre tap.
On powering up the GrandMaster the machine comes alive to the point where the motor arm will move but it will only go to the top right hand corner and there it stays witht he GM making a fairly loud buzzing noise.
There are no lights of any kind so i am leaning towards the machine itself having a fault of somekind.
My only doubt and this is where you electronics guys will be able to help is with the power supply itself.
A voltage test shows when the machine is in use that there is 14 vac on the 12 vac feed and 7.1 vac on the 6 vac feed from and to the GM from the transformer.
Would this slight overload 14 vac and 7.1 vac instead of 12 vac and 6 vac on the supplies be enough to stop the GM from working properly or is there a tollerance witht these things?
I can actually get a proper power supply shipped in from the USA but it will be around £50 with the shipping and obviously do not want to do that if it is the machine that is faulty.
Any help much appreciated.
Thanks.
Thanks.
