Choosing by pass and decoupling capacitor for an optocoupler
john
Hi all,
I am trying to figure out the size or capacitance value for the
following chip ( IL- 715 ),
http://www.nve.com/Downloads/il71x.pdf
I know that I can use the following formula to find the capacitor
C = ( I x N x t ) / V
Where,
C = Capacitance
I = Current needed to switch output from low to high
N = number of outputs
t = time required for the capacitor to charge
V = allowable voltage drop in Vcc.
The problem is that I can not find the current needed to switch output
from low to high and also the drop in Vcc in the data sheet. Can any
body give some suggestions!! Is there another practical method to
calculate capacitance value?
I am planning to use all four channels of the IL-715. The signals are
30MHz frequency clock signals.
Regards,
John
Q
qrk
Hi all,
Where,
C = Capacitance
Regards,
John
Yikes! To use this formula means you need to know more than you could
ever hope to know about your power supply lines and the part over
temperature and unit to unit variations.
You're trying to supply a low impedance power source to the part,
especially when switching. The job of the decoupling capacitors is to
handle the current spike on the power supply lines during transitions.
You must think about the layout of the parts as trace length on your
bypass capacitors will increase inductance which increases the
impedance at higher frequencies.
For this sort of thing, you can use basic rule of thumb design
guidelines - use 10nF caps real close to the power supply pins
(minimal loop length between the power and ground pins). One or two
100nF caps nearby is also a good thing. Somewhere on the board, you
should have some bulk capacitance in the 100s of uF which takes care
of the lower frequency garbage. The bulk C is for all your circuitry.
It's also good to have a solid ground plane and power plane closely
spaced. The planes will form a good quality capacitor which aids in
decoupling. At least a solid ground plane. With power and gnd planes,
you could probably get by with just the 100nF caps close to the power
supply pins and ditch the 10nF parts.
After you lay out your circuit, monitor the power supply pins on your
parts and see if the noise is acceptable (usually less than 50mVpp).
Be sure to use proper oscilloscope probe grounding procedures for high
speed signals or you will end up with a higher noise reading. Proper
grounding technique: don't use the dangly ground lead on your probe,
connect the probe ground ring to the board system ground. You can use
a small screw driver to bridge the ground ring to system ground.
DJ Delorie
John Larkin said:
Use a 0.33 uF, 0805 or 0603 cap per side, per chip. That will be
plenty.
Why that much? The spec says 47nF low-ESR per Vdd.
john
I know the thumb rules etc. But I am looking for some formula or
mathematical solution to this problem. I know 47nF valus is given in
the data sheet. But how did they come up with that?
I read the following note from texas instrument , Please take a look
at it,
http://focus.ti.com/lit/an/scba007a/scba007a.pdf
The note has the formula which I mention in my post. I am unable to
find the switching current value.
Regards,
John
