TSL
- Jan 1, 1970
- 0
Final stage of rebuilding 1940's 10" Craftsman table saw (think
tank/bulletproof) with belt drive. Been doing some electrical research
while setting up my woodshop. Using Allen Bradley switches with
key-lock on/off and 2 e-stop buttons for each of the larger power items
(one at the switch panel and one on or directly next to the repsective
machine), along with swap out of all larger 120V tools to special plugs
so switch panel can't be endrun. Have 13yo son and don't want
curiosity getting the better of him and his friends in my absence.
Questions:
1) can and should an AC motor starter be used on my 10.5 amp 230V 2hp
3450rpm drive motor to give the motor longer life - and if so should an
electric brake be installed also? What are the theories and pros/cons?
2) what is the difference in design between a transformer rated switch
@ 120V 50/60htz versus a "full voltage" switch with identical rating -
are the contacts supposed to be different? I ask because I noticed in
my quest for the AB switches (bought used to save money) the contact
blocks for the switches appear identical in both design and model #
regardless if they are rated/listed for transformer power versus full
voltage (which I'm assuming is raw power from my house).
3) what in blazes does the "L1, L2, L3, etc" and "T1, T2' T3, etc" tags
mean in motor circuit and wiring diagrams? I'm assuming that "common"
is the nuetral. And when the nuetral and ground from my box (WA state)
are joined, how, if at all, are they to be distinguished at the motor?
Nuff for now. TYIA!
TSL
Questions:
Nuff for now. TYIA!
TSL
