Cleaning blue-green crud from battery area of scanner
jbclem
I have a portable scanner, Regency HX 1500, that I haven't used for quite a while.
There is a lot of powdery blue-green stuff that covers the metal battery
connectors/tabs. I've cleaned it off with q-tips dipped in alcohol, but it always comes
back. I'm storing this scanner without the AA batteries it uses...is there a way to
permanently stop this blue-green and what exactly is it?
John
James Sweet
John
It's corrosion from traces of battery electrolyte. Clean it off with
vinegar, that'll react with the alkaline electrolyte and neutralize it. Then
wash it off with water and dry it out.
3
3T39
Hello, James!
You wrote on Mon, 25 Jul 2005 00:24:42 GMT:
JS> ??>> I have a portable scanner, Regency HX 1500, that I haven't used for
??>> quite
JS> a while.
??>> There is a lot of powdery blue-green stuff that covers the metal
??>> battery connectors/tabs. I've cleaned it off with q-tips dipped in
??>> alcohol, but
JS> it always comes
??>> back. I'm storing this scanner without the AA batteries it uses...is
JS> there a way to
??>> permanently stop this blue-green and what exactly is it?
??>> John
As well as cleaning the area it would be a good idea to smear the terminals
and any other metal parts in the battery box with light grease to prevent
further deterioration. you don't have to clean the grease off to use the
scanner as it wont interfere with anything.
With best regards, 3T39. E-mail: [email protected]
N
NSM
It's acid. Try warm water and baking soda to neutralize it.
N
jbclem
Thanks all for the answers. I tried vinegar on q-tips but that doesn't seem to get rid
of the blue-green...some came off but there's still plenty left. I'll try water and
baking soda next but I'm a bit worried about water seeping into the electronics...any
ideas for preventing that (I could hold the scanner upside down but that might be
awkward.
John
N
NSM
awkward.
I soaked an entire portable CD player in that solution - worked fine ever
since, but it helps to know what you are doing. Make up a paste of water and
baking soda and apply to 'crud'.
N
James Sweet
awkward.
John
Don't use baking soda, it's not acid, it's a base.
jbclem
Well I've tried warm water and baking soda...it may be neutralized now, but it's still
blue-green. And there are small openings in the metal battery connections with the
blue-green down inside. Am I going to have to scrap this stuff out with an ice pick?
And a magnifying glass?
John
N
NSM
Could be. Or try WD-40 and leave it on for a bit.
N
James Sweet
John
Vinegar will neutralize the battery fluid, but you'll still have to scrub
off the corrosion from it.
Jim Adney
The green is probably a copper oxide that formed when the battery
contents leaked on the contacts. You can try vinegar, but rinse it off
well and let it dry when done. It may take awhile but it will clean
metal corrosion up rather mildly.
I've used a dental pick to scrape those down to clean metal to get
good contact again.
I use a good grade of bearing grease to coat the contacts and battery
ends to prevent further corrosion. The grease contains corrosion
inhibitors and keeps the air/oxygen away from the parts. The contact
pressure will still push the metal parts together and allow electrical
contact.
jbclem
Thanks everyone for the advice. Looks like I'll be scraping away for a good while.
John
