measuring neutral to hot which is 120 VAC
Measuring Neutral (white wire ) to ground i think or its neutral again to a breaker
One side of the switch goes to HOT , the other side of the switch goes to either neutral or ground
But when I'm measuring the AC voltage , I measure with my black probe to the neutral white wire to the HOT sided lug when the switch/breaker is open, It reads 3 VAC when the switch is open and I'm measuring with my DVM meter from the white neutral wire to the HOT black wire sided lug on the switch
I get 3 VAC when the switch is open, measuring from the HOT side of the switch/breaker lug terminal to the white neutral wire
